Stock LQ4 + boost..... How much will the stock cam hurt vs. LS6?
Got my LQ4 in my RX7 and as it sits it is bone stock (even the pan!) besides an eddy intake & blowthru carb. My question is this:
if I shift @ 6000rpms will changing the cam really help?
I don't see the need to turn the motor super hard (7000) if it's not really gonna make a bunch more power. I understand driveability will not be a factor as both are stock cams. I already have the LS6 cam and springs. The rx7 is very light (back-half car) @ around 2300 #s. Car will be driven regularly on the street at around 14#s boost. So would I see tangible gains from the cam swap? Right now seems like alot of trouble for minimal results. Convince me why it's not
do you have pics of your setup?? would love too see
I would change the cam, Why do i feel like i saw a dyno graph of the stock cam falling hard off after 5500rpm. I wont swear to this, but i think i remember. And if youve got it, use it
I remember when I asked this last year, people were saying they were picking up almost 40whp with just an ls6 cam over a stock ls1 cam. I would expect similar results with an lq.
I'm gonna get some real results against stock, LS6 and a lingenfelter -3.
Any negative feedback n the yellow ls6 springs? They look pretty weak, I understand they work great for stock apps but repeat high rpm pulls against boost? I've typically used slghtly overkill valvesprings on my SBC.
I find it hard to believe a cam would make it just all of a sudden break up and drop power rapidly once it hit 5000rpms. That has nothing to do with the cam....valve springs maybe. That dyno graph with it breaking up has got to be something else.
My friends BMW with a 5.3 in it has the stock cam, stock ls1 intake, we put better springs in though... it pulls and pulls up to 6500 and wants to keep going on 15psi.
The factory's advertised RPM band for that cam should increase with boost I would think.
Seems to work just fine.
Found the thread: https://ls1tech.com/forums/forced-in...o-numbers.html
I really want to agree with the valve float theory. The results are hard to dismiss though. Even if you just compare the numbers before the 5000 "peak" the z06 cam seems to be surperior enough to warrant a change considering cost & effort.
