???help with injectors for my combo???
been out of the loop for 5 years now and finishing my 2000SS before tunerunning a ls6 lingenfelter long block with larger diamond dish pistons coated(lunati billet internals), arp studed main & heads ls6 intake, sump tank speedinc full fuel system(sx pump,-10line to y-block -8line to rails boost reg -6line return), D1SC with 3 core intercooler 3" piping 15lbs boost, mondo bypass valve and running pump gas.
The combo i bought 6 years back came with 45.4lb injectors(well thats what is ingraved on the side, or is that PSI??), So my question is with stock PCM for tune with 93 pump gas and 15lbs boost are those injectors to small?????
Thanks Guys
