Eboost 2 can I get to 20psi on 7.5 psi gate springs
Can I get to 20psi on 7.5psi gate springs with my eboost2? On my talon I had to go up on springs from 10psi to 20psi as found could only get about double spring pressure out of it but was using manual controller. I have not tried to see how far can take the 7.5psi springs just was running them on gate pressure only last season but now want to go up on boost with new combo and be able to ramp up boost .For ramping its handy to have 7.5 for low boost and then go up from there. 10psi would be a lot of boost /power but don't want to get limited to 15psi max want to be able to get to 20 or so max.
So whats the verdict eboost 2 guys?
Which two port connection method are you guys using (1 or 2)? I'm using the two port connection method (1) on my Eboost2, but I've wondered how the method (2) would do?
Turbosmart also lists in the most recent online manual (http://www.turbosmartonline.com/index.php?s=downloads) a two port method (3) that uses an optional four port solenoid for a wide range of boost pressures. I wonder how it would do?
