turbo sizing help
Old Jun 23, 2011 | 08:27 PM
Blown02Camaro's Avatar
Default turbo sizing help
Ok Iv got a 383 stroker ls1. Im in the process planning my turbo kit with meth injection but i'm stuck on what turbo I should get. My goal is 700-800 at the tires. Can a t76 or a t78 support that much with out pushing the limits of the turbo? or should I go bigger?
Old Jun 23, 2011 | 09:24 PM
ModularTurbo's Avatar
There are many options out there and yes a 76 or 78 can do that, there are bigger turbos that will do it also.
It comes down to a few different things, how much room you have to mount it, how much money you have budgeted for it, and how you will be using the car.
Also some slight adjustments for your engine combo.
Give me a call and we can discuss your different options.
thanks
Old Jun 25, 2011 | 10:18 AM
ZL1Killa's Avatar
modular is correct. a 76mm or 78mm from a good manufacturer will make that power. On my 347 ls1 (Stock bottom end) ls6 heads, custom cam, forged pistons, forged rods at 15psi I'm making low 700s and there is breathing room left
Old Jun 26, 2011 | 08:01 PM
Nice. as long as I can make the power I want and not have to worry about **** going wrong im good
Old Jun 27, 2011 | 11:15 AM
DrTurbo's Avatar
LS1TECH Sponsor
Its not a problem, but the turbine wheel is the key for a 383. We can help you...just let us know. We can build you a custom unit to your spec or we have tons of off the shelf units.
