LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   those running 5.3's (https://ls1tech.com/forums/forced-induction/1442887-those-running-5-3s.html)
southpaw0314 Jul 8, 2011 10:20 PM
those running 5.3's
how many miles did your 5.3 have before adding boost to it? Did you do anything to refreshen it?
07MCSS Jul 8, 2011 10:49 PM
51,000 on an otherwise stock LS4. I've never removed anything from it other than the front manifold to replace the thermostat, not even a valve cover.
JRENIGAR Jul 9, 2011 10:25 AM
So what does it make, and for how long?
07MCSS Jul 9, 2011 02:37 PM
It made 370 hp with about 5psi at the gauge last fall. It has 56000 miles on it now. I had some tuning issues early on with it stumbling at wot. That was cleared up at the expense of tuner pulling timing to help fix problem. I'm running 10.5 wastegate springs now seeing about 9psi at the gauge. No new hp numbers yet. I'm having it retuned this summer and switching to speed density. I had a fuel issue that was finally resolved by taking the car in to the dealership. They replaced the fuel pump, fusebox and replaced the pins in the fuel pump harness a couple of months ago. No issues since. I have yet to do anything to the engine itself. Knock, knock.
JRENIGAR Jul 9, 2011 04:30 PM
Do you beat on it often or just cruise for the most part? Im going to change mine out for a 5.3 soon and thats why Im intrested. thanks.
07MCSS Jul 9, 2011 05:46 PM
Mainly I just cruise. Everyday I pull a way from a stoplight at least once for an agressive 1-2 shift rush. No quarter mile stuff though or just going out flogging for the hell of it. It's all I have to drive so I can't afford any breakdowns.
JRENIGAR Jul 10, 2011 09:48 AM
So you have put roughly 4k on it since the boost was added? If the ls4 5.3's are as tough as the truck iron block 5.3's then Id say you have nothing to worry about. My stocker has 178k on it and I dd it 110 miles a day. It has been boosted for roughly 10k so far and I usually just do 60-120 blasts when the need arises :devil:.
quicksilverado Jul 10, 2011 09:52 AM
I put a magnacharger on my 5.3 at 90k. At 150k I switched to a turbo. It put 320 to the wheels with the s/c and 500 with the turbo. I was a track whore for 2 years. It was a DD that saw about 30k miles per year. I broke a piston at just under 200k miles.
JRENIGAR Jul 10, 2011 05:51 PM
What kind of boost did it take to make 500rwhp and was it completely stock longblock or??? BTW thats good info. I plan to replace my 180k engine when this one goes but cant decide if a cheap 5.3 or a 6.0 is the better way to go $ vs hp wise...
southpaw0314 Jul 10, 2011 09:34 PM
I found a 5.3 with 160000 miles for 200. what do you think?
91blowthru Jul 10, 2011 09:41 PM
if the pan isnt full of sludge and such, id run it without hesitation. Hot Rod magazine did a 5.3 turbo with 150,000 miles and made high 5XX hp non intercooled, and after they took it apart and said bearings and stuff looked totally fine. good luck!
skinnies Jul 11, 2011 12:57 AM
We've done several motors over 150k miles and worked great, my aluminum motor has the least miles of anything we have built at 100k miles.
hitmanws6 Jul 11, 2011 01:08 AM
I will be adding rodbolts/head studs and plan on making 550ish. Quik made 700 with just rodbolts on his 4.8 spinning to 7500 on 16psi.
T/ALT1 Jul 11, 2011 07:39 AM
Wow 700 with a stockish 4.8 and turbo? Thats crazy, you can buy 4.8's for $200/piece too. Later
Loudmouth LS1 Jul 11, 2011 01:09 PM
Where, I need one, haha!
quicksilverado Jul 11, 2011 04:16 PM
It was a while ago, but I believe it was 9 psi. The only thing that was not stock were the 918 springs.
Black98s10 Jul 12, 2011 02:47 AM
I got my lm7 5.3l off ebay for 350. The guy shipped it to me for free and it has 140,000 on it. I might eventually rebuild it, but I'm just going turbo it and not worry bout the miles. Imo, if your going to crazy with boost, I'd go with a truck cast iron motor. I hear they are stronger.
pwrtrip75 Jul 12, 2011 09:20 AM
I got a 5.3 from LKQ, high mileage, but mileage didnt matter because i couldnt care less how far its traveled.... but it was in decent shape. Lasted 3 years of some serious beating making 640hp to the wheels. Stock bottom end was never touched.
Mileage is for warranty stuff... its meaningless with engines. 100k miles on a truck with 4.10 gears will be different then 100k miles on one with higher gears. Driving habits, maintenance, ,.... etc. 10 different engines from 10 different people all with the same mileage on them will all be different.
NEVERTWOFAST Jul 13, 2011 08:27 AM
My buddy has a cast 5.3 on 11psi and beats on it hard every day for the last 6 months and has had zero problems. It is 100% stock.
JRENIGAR Jul 13, 2011 10:20 AM
This kind of info gives me hope, do you know his #'s or how many miles he has put on it, how many it had when he got it? Thanks.
© 2026 MH Sub I, LLC dba Internet Brands
