procharger ducting q's?
Old Aug 14, 2011 | 11:32 AM
81cuttysupreme's Avatar
Default procharger ducting q's?
Is there any advantages to getting rid of couplings when it comes to ducting? Is it worth trying to get some custom welded longer sections of pipe so I dont have so many couplings? Less leaks? Smoother air flow? Look cleaner? Also can anyone reccomend a place to get mandrel bent 3" tubing? Is there any difference between aluminized steel? Mild steel? Stainless?
Old Aug 14, 2011 | 02:06 PM
1INSANEGTO's Avatar
Go with alum. You can get it pretty cheap on eBay
Old Aug 15, 2011 | 07:18 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I agree, plus the alum will not get rust scale inside of it and is a lot lighter than steel. Make sure the ends are bead rolled to keep the hose/silicone from blowing off. You can buy a manual bead roller although they are expensive. T bolt clamps work much better than band clamps for securing the plumbing. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 15, 2011 | 09:21 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I've also read where you can spray the pipe with some hairspray prior to putting on the coupler and at first it allows it to slide on easier, but once dry, it helps seal the connection.
Old Aug 15, 2011 | 04:07 PM
Avengeance's Avatar
Interesting... Im gonna try that when I install my F1.
Old Aug 15, 2011 | 08:07 PM
so there doesnt seem to be much concern about # of couplings? I was curious if anyone had found a noticable difference by getting rid of couplings and welding different pipe sections together?
Old Aug 16, 2011 | 06:47 AM
LS1Tech Sponsor
The only way I see the added couplings causing a problem would be if they were either leaking or causing a restriction in some way. Good quality four and five ply silicone and t-bolt clamps are not cheap, so you could potentially save some money by welding the system together. This could also eliminate the possibility of future leaks. Bob
__________________
