procharger conversion vehicle q's I am still working on getting my procharged ls6 into my 81 cuttlass. I have a few issues I need help on. 1. The ps pump has been giving me alot of issues. Is the 5/8 hose inlet for the ps pump(i have a C6 pump) pressed in? Can I take it out? Can I press in a 5/8 tube with a 90 degree elbow in it? Does anyone already make this elbowed fitting? 2. For the iat sensor. Do i need a sensor that will thread into my inlet tubing with a bung? will an 88' camaro v8 iat sensor work? will it work with a 99' LS1 pcm? will it work with the factory harness plug? 3. What size couplers do I need to go from 3" tubing to factory MAF and factory throttle boddy? Thanks in advance for any help. |
You can get a iat sensor from a Typhoon/Cyclone from any auto parts store, they work. The maf is 3.5", not 100% sure but I think the throttle body is 4.25" or close to it. I had a hell of a time finding a coupler for it. www.siliconeintakes.com is where I ended up finding mine. |
thanks. anyone know about the C6 ps pump inlet tube? |
i found the iat sensor at autozone. just wondering if someone makes a 90 degree press in fitting for the ps pump. |
any ideas on the ps pump? anyone? how to get a tight radius fitting on the inlet of the pump??? |
The pump fitting is pressed in the pump, I was able to get mine out and rotate it then press it back in so it would work with the transplant bracket. |
Man I could not get mine out for anything. How did you get it out? |
I used a litte heat on the fitting just warm it up don't get it so hot that the metal fitting gets soft and try to rotate it with a pair of channel locks and it will come out just take your time. |
Ah. I was worried about applying heat. Didn't know if it would cook the pump. |
| All times are GMT -5. The time now is 05:05 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
