Bolt on turbo kits?
Nope still waiting,but they put a .25bar spring in the wastegate for me so i can run on 3psi until i make it too the dyno for tuning which will be in like 3 weeks after the install, and they had to make the turbo to fit 3inch piping instead of the stock size 2 1/2
And i will have track times on 3 psi and dyno #'s on 3 psi With no tuning ,then et's And Dyno with fuel pump injectors tuned 5psi then the same but tuned 8psi with methanol
