TT setup and cam???
Old Mar 17, 2004 | 01:15 AM
CAT3's Avatar
Restricted User
Default TT setup and cam???
I imagine my current TSP 231/237 .598/.595 @ 112* lsa is not a good choice for a TT setup seeking huge numbers? Most seem to run close to stock, so I have been thinking the Z06 cam would be a good choice. Any ideas?
Old Mar 17, 2004 | 08:18 AM
stealth's Avatar
Call CRane, Comp and other cam grinders and ask them to spec you one. Turbo cams are very different from blower cams or NOS cams, and generally have a lot less duration. I'm not a turbo guy but I would expect durations around 220.
Old Mar 17, 2004 | 12:00 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Try BBrannen@compcams.com I think that Brian is very responsive to emails. And yah your current cam is not going to help you with peak HP numbers.
Old Mar 17, 2004 | 03:56 PM
Noyzee's Avatar
8 second mod
i made good power with my last 2 custom grind. i guess about the same as most.
my old cam was a 222/216 563/563 @116 and my new set up is a bit bigger more around 230 570 114
seems to make more tq with the same boost and more power threw the rpm's.
im happy with both.
Both where a mix between everyone i talked to and what i thought. it isnt exactly what anyone said, but it works prety well.
Old Mar 17, 2004 | 08:57 PM
CAT3's Avatar
Restricted User
Cool, thanks for the tip to Brian there John. And Noyzee, seems to be the case when I ask one person and the next I get two totally different answers.
Old Mar 18, 2004 | 07:20 AM
Noyzee's Avatar
8 second mod
that you will, as did i. thats why i ended with a mix between all the answers! NOYZEE Custom cams! hehe
Old Mar 19, 2004 | 10:20 AM
Shinobi'sZ's Avatar
Depends on the Turbo size. I think Harlan had a nasty cam (112 lsa) by Turbo Standards and made excellent power. The Z06 cam is a very good choice, however if you are going to go through the trouble of swapping cams get a custom cam or a Comp Xer cam. What size Turbos do you plan on running...a they small, medium, or large???? That is really the first question you need to consider.
