Turbo Firehawk build up V 3.0 AES 385 and S88
Old 07-28-2012, 12:46 PM
  #261
Cam72aro's Avatar
Originally Posted by tording99Z28
Yeah the crazy thing is when I called Callies and talked to them about the crank that was in it they told me that the "C" series crank is a budget crank that is only rated to handle 600 HP. I verified this with them several times and they told me this every time yet it is used in quite a few high horsepower applications. They must severely underrate their cranks is the only thing I can gather. Hopefully the OP has better luck with his.
I see in your sig you have a gt91? I am finishing up my build with that same turbo. DO you like it? What exhaust ar and t4 or t6? I ran a eagle budget 4340 crank a few years back in a 406 gen 1 small block making around 900 at the crank on the gas and it never failed. I think that crank was only rated around 650hp. I have an eagle crank in my 408 right now. Not really sure what its rated to, but can imagine I will go past that with the turbo I have on it.
Old 07-28-2012, 12:51 PM
  #262
tording99Z28's Avatar
Yeah for a budget turbo it works great, it is a T6 and I am running a 1.38 exhaust a/r.
Old 07-28-2012, 01:06 PM
  #263
Cam72aro's Avatar
I am a t6 with a .96 exhaust ar.
Old 07-29-2012, 03:05 PM
  #264
98Camarod's Avatar
Originally Posted by dschmittie1
It has been crazy hot here the last 2 weeks. I am finishing an Cam install on a c6 vette today for a friend, I bought a Duranmax truck to make hauling my car around a little nicer. And I still need to buy new tires for the car. The plan is to do that once I get paid for this side job.
Sounds like a plan. I ordered my 411 pcm yesterday. I'll be starting that swap probably next weekend.
Old 08-05-2012, 03:21 PM
  #265
dschmittie1's Avatar
Well new tires are installed and the plan is to head to Cecil Wednesday night to make some passes. I can't wait to see what it does on some good tires. I plan to make one or 2 low boost passes then I am gonna turn it up
Old 08-05-2012, 03:28 PM
  #266
Awesome man, good luck!! I know about some traction issues.
Old 08-05-2012, 07:52 PM
  #267
jrpimp00's Avatar
Great build, im subscribing because I will be starting my FI LQ4 build this month
Old 08-08-2012, 11:00 PM
  #268
crazy3rdgen's Avatar
Did you make it out tonight?
Old 08-09-2012, 07:51 AM
  #269
Yep I made it to the track last night. had some minor issues but over all it was a good night. All passes were on low boost 6.5 psi
first pass off the trailer
10.28@134 with a 1.9 60' two step at about 3200 rpm
2nd pass
raised the two 3600 rpm car felt like it bogged a little nothing major 1.8 60' I don't remember the rest of the pass.
3rd pass
3800 rpm 2 step car fell on its face. I thought I had my foot on the brake pedal a little not letting my secondary 2 step stay on.
4th pass I removed the 2 step just for testing and noticed the car was loading up on the trans brake.
I went back to the pits and worked on the tune when on the trans brake.
5th pass 1.5 60' still a little rich on the trans brake but ok 10.20@134.1mph
I will note that my shift light wasn't working I think I may have snagged a wire for if when I was fixing some relays the other week.
My next outting will be in another week of 2 and I plan on truning up the boost then
Old 08-09-2012, 08:08 AM
  #270
98Camarod's Avatar
Not too shabby for your first runs. How were the IAT's? I sent you an email btw
Old 08-09-2012, 09:15 AM
  #271
I got your e-mail I have just been really busy and haven't always had my laptop with me to send that to you. I will try and send it tonight.
I will also look at my logs tonight to see what my IAT's looked like. My guess it HOT
Old 08-09-2012, 09:47 AM
  #272
98Camarod's Avatar
Haha I'm sure they were. Mine were steaming last time I went. No rush. My car will be down here shortly for the pcm swap.
Old 08-09-2012, 01:01 PM
  #273
Well just looked through my logs quick. Last pass I shifted out of 1st at 6100 rpm and 6000 rpm into 3rd.
Also my IAT's were only were 124 at the begining of the pass and 120 by the end. I guess my A2A is doing pretty good. I also plan on hooking my Meth back up in the next couple weeks for some high boost stuff and just to help reduce my IAT's. outside temps were around 80 and it was humid.
Old 08-09-2012, 04:45 PM
  #274
98Camarod's Avatar
That's really good. Mine started out at 129 and ended at 155. It was in the 90's though and 100% humidity.
Old 08-13-2012, 08:46 PM
  #275
Here is a video that someone else did of my car from last week.
I will be heading back down to the track again this Wednesday so make some more passes. Also planning on turning up the boost this week
Old 08-13-2012, 08:55 PM
  #276
mike13's Avatar
how do you run a 10.28 with a 1.9 60' and a 10.20 with a 1.5 60' at the same mph?
Nice runs.
Old 08-13-2012, 09:27 PM
  #277
I think Shifting way to early 6100 rpm out of 1st and 6000 out of 2nd. I normally shift around 6600. Either way I know I can lean the car out more on the trans brake yet. so the plan is to go down and run a 9.8 on 6.5 psi then turn things up to 14 psi
Old 08-13-2012, 09:42 PM
  #278
mike13's Avatar
I can't believe your running that fast on 6.5lb's.
Old 08-13-2012, 09:45 PM
  #279
bad6as's Avatar
You should mesure iat and boost pre and post a2a w/ and w/o meth for me =)
Old 08-13-2012, 09:47 PM
  #280
You want to pay for the stuff to do it?
Quick Reply: Turbo Firehawk build up V 3.0 AES 385 and S88
