Turbo Firehawk build up V 3.0 AES 385 and S88
#465
ok. The problem with doing it that way is that if you have a afr % error and you copy it to paste the error over it's going to think that those areas are wrong as well. I'm OLSD, so I don't use the o2's. I was hoping there was a way to do what I wanted haha thanks though
#469
Thanks. I just went and messed with the footbraking aspect of the tune. I can't manage to get more then 95ish kpa with the footbrake. We'll see what it makes on the brake. After the trans rebuild, I can now footbrake it to 3600ish rpm vice the 3100ish rpm. I guess it's because of the different fluid I used.
How much boost do you get when you footbrake? I've got it at 8.7 which is ~13.1 on the gas scale and 30* of timing. It may be time for some nitrous until I can get more cubes.
#470
#472
It would take me close to that to hit 8 psi on the brake. Maybe look at getting a 3 step to help spooling before you stage? It probably wouldn't hurt to change the housings either..........I miss that set up! I kick myself sometimes for not keeping everything
#473
Not much new to post right now. Just trying to get everything in order to head to LS fest next week. I added some new LED light to my trailer to make things brighter and help with strapping down the car. I added LED strip lights to the floor under the car and I also replaced the regular ceiling lights with LED and added a 3rd ceiling light.
#475
Well the car and Truck are all loaded up and ready to head to LS FEST after work tomorrow. The car got treated to a fresh set of tires and new front brakes today so we should be ready to rock and roll. I will post updates here when I can but it people want more updates you can find me on facebook at
https://www.facebook.com/profile.php?id=1411595483
#477
