ms4 with d1 procharger?
EDIT: I just reread your first post. That MS4 has a high rpm range range and with the D1 the higher the rpm the more boost you will make. And for a stock motor that is a ticking time bomb making boost at high rpm!
Make sure the "FUEL SYSTEM" is up to par, a "REAL GOOD TUNE" .
Limiter is 7,000
I shift at 6,800 yea I'm crazy if it lets go I know why.I can't complain 3 years and some hard 6,000RPM + launches and still going!!
Tune by Alvin "PCMFORLESS" he made sure it was a good, safe tune!!
I could tell it lacked a little on bottom when (cam only), which is fine for me it doesn't bother me.My car is geared 4:10 which helped when cam only. The cam does have some bleed off which helps to forgive alittle on the motor.
When not in boost yea it suffers in lower RPMS with blower, but a blip of the throttle into boost its fine. The power my car made was more then we expected really.
