Oil returns on turbo setups.
The good thing about this location versus up front from the bottom is, if a cup of oil goes in the turbo, a cup comes out, whereas when the return is in the bottom of the pan, oil always sits in the line until the oil right out of the turbo is heavy enough to push the oil up the fitting and into the pan... oil should never sit in the return line. Every bit of it should exit out into the pan. Also when the car accelerates, this will help the oil move out of the line is the majority of the line is parallel with the cars direction.
The measurements i got are 4" up from the bottom of the pan and 1.5" left of the front of that pan reinforcement vain... but it is hard to get an exact measurement as the vain is not perpendicular to the bottom of the block. These measurements are to the center of the fitting, 1/2" NPT... same as MM. And i used his 3/4" hole saw on a right angled drill with a vacuum cleaner sucking the shavings while i was drilling. Just be careful about the section you cut out, you don't want it to fall in the pan. A little grease in the hole saw will help. 3/4" is actually a little larger than the required drill size for 1/2" NPT but i was unable to find the right size (45/64") in in a hole saw and my right angle drill only has a 3/8" chuck... so the right jaber drill bit i should have used would not have worked. The 3/4" is actully a little better i think as it was much easier to start the tap.
I marked those measurements and made sure once drilled that the fitting had clearance from the vain and the bottom of the pan/bolt head before drilling.
I say compare what numbers MM's gives you, along with mine and call George to see what numbers they wrote down. I know when i am making stuff at work....I always try to stick with even numbers/fractions where i can to make things simple.... and figured George did the same.
Lastly.... call George on any oil return issues. He said the main issue is because of too much crankcase pressure, were as it only takes 1-2 psi to stop the oil from coming out of the turbo. It doesn't take much to create a couple psi if the pcv is not sufficient(large enough filters), if the one-way valves are leaking with boost, and/or there is some blow-by.
only thing is though i would not want to drill into the webbing.
To find out exactly how high the oil sits in the pan why not fill an uninstalled pan with quarts of water?
not all 5 quarts will be in the pan.
also my fitting from the bottom (original location) stuck up another 1/4-3/8 inch which would hinder draining.
. But just untill you get out on the road and clean out the exhaust real good.
