LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   I'v got a question (https://ls1tech.com/forums/forced-induction/1524918-iv-got-question.html)
Blown02Camaro Mar 11, 2012 12:59 AM
I'v got a question
Iv got a serious question. I'm having my 383stroker fixed because the machine shop that the shop used boarded it out more than they thought to clean up the bores which caused my engine to use an excess of oil because there was to much space between the rings and the walls of the block. They are fixing it on there pockets. My question is I'm planning on boosting it to the tune of 600-700+ wrhp, so the pistons are going to be custom made to fit. Will the extra material removed making the walls thinner be an issue at that power level?
got-a-ls1 Mar 11, 2012 01:24 AM
information such as how much they bored it would help
allout06 Mar 11, 2012 05:44 AM
If its ur ls1 block, they don't really bore the block, they just torque hone it. And thinner walls are more likely to crack if detonation occurs. Have them resleeve it.
Blown02Camaro Mar 11, 2012 09:16 AM
All the indie I have I gave. He didn't know how much they has to bore it out. I will find out tomorrow when I call. They had to bore it because my number 7 piston decided to let go so it score up the walls. How much does it cost to re sleeve the block?
got-a-ls1 Mar 11, 2012 11:06 AM
costs a lot to sleeve it.. and not just any machine shop can do it.
sounds like a good time to move up to a iron 408 if your gonna get new pistons anyways. pistons will be cheaper as well because your talking custom pistons vs shelf pistons. can reuse the came crank and rods in the 408.
ssnovaturbo Mar 11, 2012 02:01 PM
If you reuse cam, crank, and rods, it wont be a 408. It will be a 370. Only way to get to a 408 is stroker crank
ssnovaturbo Mar 11, 2012 02:02 PM
My bad, missed the 383 part
Blown02Camaro Mar 11, 2012 06:22 PM
So what would be the cheapest solution if worst comes to worst?
ssnovaturbo Mar 11, 2012 07:32 PM
Find a lq4/9 block and enjoy the extra cubes. Probably the cheapest and best solution
Blown02Camaro Mar 11, 2012 07:51 PM
Can I use any of the parts I already have?
ssnovaturbo Mar 11, 2012 08:04 PM
Everything, just need a new set of pistons which you need anyways
Johnv Mar 12, 2012 12:22 AM
Or get a 5.3 cast block and use your current engines rotating assembly to build a cast 383..
Blown02Camaro Mar 12, 2012 11:30 AM
Ok I talked to the shop and the final bore will be 3.910. Im going to keep the stock block and just keep it around 600-650 at the tire. Ill start piecing together a 408 once I get it running.
Blown02Camaro Mar 12, 2012 04:36 PM
Do y'all think that 3.910 bore will be fine at 600-650rwhp?
© 2026 MH Sub I, LLC dba Internet Brands
