Big power REAL street cars- check in
#82
[QUOTE=ls2 goat;16207424]Made 837/689 on pump and meth, 14 pounds pounds of boost, and through a DSS 9 inch IRS and some MT 345's.
Warhawk 427
Procharger F1c with a bicycle tire pulley (5.25") making 14 pounds barely spinning it.
Alky Control Meth kit
Worked over Beck sheet metal intake
FIC 120cc injectors
DSS 9 inch
CCW 18x12s with 345 DRs
/QUOTE]
Hey Jeremy how do you like it. How many miles have you put on her in 4 days. jeff
Warhawk 427
FIC 120cc injectors
DSS 9 inch
/QUOTE]
#83
Well my car got driven to and from work 2-3 days a week plus plenty of weekend beatings etc and ran great all year without so much as nipping a plug, put on around 4500 kms I would guess.
FPS built 370 cube ls
stock crank
stock 6.0 block
stock 317 heads ported
callies H beams
Diamond pistons
custom grind cam
stock size arp head studs
ported fast 90mm intake
80lb injectors
twin magnum 76's via Rob@modular turbo
1.80 straight cut glide
3.31 rear gear
column shift![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
23psi and c16 made 1108 rwhp with a somewhat loose converter and on pump/meth it went 9.0@155 leaving soft and on good fuel 8.47@164.5 .
![](http://i1103.photobucket.com/albums/g478/HorsepowerSolutions/270023_10150321914665751_658515750_9826672_1967863_n.jpg)
stock crank
stock 6.0 block
callies H beams
Diamond pistons
custom grind cam
80lb injectors
3.31 rear gear
column shift
![](http://i1103.photobucket.com/albums/g478/HorsepowerSolutions/IMG_2330.jpg)
#84
stock crank
stock 6.0 block
callies H beams
Diamond pistons
custom grind cam
80lb injectors
3.31 rear gear
stock crank
stock 6.0 block
callies H beams
Diamond pistons
custom grind cam
80lb injectors
3.31 rear gear
column shift
#85
[QUOTE=stngtamr29;16209239] Drove it home Sunday (400 miles) and haven't been able to take it out since due to rain and my schedule. I'll be cleaning it up tomorrow, changing the oil, and getting it out on the road ASAP. Can't wait to see what the retune on yours nets.
That is sick. Bet a ton of feelings got hurt with that thing.
Now that sucks.
Warhawk 427
FIC 120cc injectors
DSS 9 inch
/QUOTE]
Warhawk 427
FIC 120cc injectors
DSS 9 inch
/QUOTE]
stock crank
stock 6.0 block
callies H beams
Diamond pistons
custom grind cam
80lb injectors
3.31 rear gear
stock crank
stock 6.0 block
callies H beams
Diamond pistons
custom grind cam
80lb injectors
3.31 rear gear
column shift
Now that sucks.
#86
Restricted User
Here is LS2Formula. I tune and spec'd out this combo. Not my car.
It's a LSX 422 (built by TEC) w/ twin PT7675's, TFS 245's, Solid Roller, Wilson Billet Intake and KYTP custom A2W kit. 3650 race weight.
![](http://i54.photobucket.com/albums/g81/ls2formula/d2512338.jpg)
http://www.youtube.com/watch?v=f8WTHrojnms
Another angle. This video also contains a slower pass in the beginning.
http://www.youtube.com/watch?v=afeZY6LUnQc&hd=1
#87
It was not "parted out" I sold the engine combo to fund my new one:
https://ls1tech.com/forums/forced-in...56k-death.html
Both cars will be back out this one will be a little more mild and the new one a little more wild. One will run 9s and one will run 7s both on radials.
#98
I don't consider mine "Big" power at 1070rwhp, there are a ton of 1500+rwhp street cars in DFW, however mine is 100% streetcar that sees the track as much as possible... built to drive in 5 O'clock traffic 110*+ Texas heat, and does it without a fuss...
