F'ing ATI started my D1SC install this weekend...took me forever to get the friggin balancer bolt out...my dads pos air compressor/impact didn't work worth a damn...a little shop air (from a buddy) cranked it right off! Anyway, ATI forgot to send me the nice extended bolt/flat washer for the crank pulley....ASSES!!!!!!! Other than that, I got the bracket on and installed the intercoolers (that was a little pita too) |
It will all be worth it when its done. Trust me. |
Oh yes it will!!! |
yeah i can't wait...it just sucks that I couldn't get it all done in a weekend. I can't believe how much time we wasted with the crank bolt and mounting the intercoolers, but i know it'll be sweet once its done!!!! |
Don't forget to either cut that bolt or add some washers. Take it from those of us who have gone through what you're going through ;) Mike |
Yea, I don't think my bolt bottomed out before when it backed out, but you never know, I'm using 2 washers w/3 threads cut off the crank bolt |
well today I got the fan done, put in the new injectors, and mounted the blower. Now i just need to get that bolt, put on the crank pulley, run the plumbing etc... are there any standard measures I should take on the crank bolt, or will each setup be different? Should i try 3 threads/2 washers like Bigbos? Thanks, Mike |
I just used 3 washers, red loctite, and tightened that sucker down to like 200 ft/lbs. Hasn't budged since. Mike |
majical word: RED LOCTITE. when installing the plumbing, get a spray bottle and fill it with soapy water, should make it alot easier. |
I have heard that the new ATI kits have the bolt re-sized anyway. So you won't need to cut or use 4 washers. clint |
Yea, I used blue locktite and probably 175ftlbs of torque and it backed out, now I cut three threads and I plan on having each thread with a healthy amount of the red stuff.....:) 250ftlbs too...... |
GET YOUR CRANK KEYED.. ;) Not as much stress to have the bolt back out.. With me spinning my blower as hard as I am, let me say that without the crank being keyed, I would have had major problems.. Clint |
| All times are GMT -5. The time now is 05:18 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
