LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   Thick deck head with the most chamber cc's.......???? (https://ls1tech.com/forums/forced-induction/1587907-thick-deck-head-most-chamber-ccs.html)
LS6427 Sep 26, 2012 03:04 PM
Is there a head with a thicker deck than factory that has a chamber size greater than 72cc?????
Which ones?
stevieturbo Sep 26, 2012 04:31 PM
My TFS heads are circa 74cc
87silverbullet Sep 26, 2012 04:47 PM
Did you get work done to them? The biggest i know of from TFS is 70cc.
stevieturbo Sep 26, 2012 04:59 PM
Oddly I'm pretty sure they were sold to me as 74cc about 5 years ago. I needed them in a huge rush, so really I was happy to get anything at the time. They are absolutely not 64cc though
But when I measured them myself earlier in the year I would have said they were closed to 72cc. Wouldnt say my measuring practise was 100% accurate though.
So my 74cc may be wrong and it could well be 70cc.
87silverbullet Sep 26, 2012 05:09 PM
Nothing is never perfect. Gotta measure them anyway, just to make sure. I have had heads be off on the cc of chambers so many times. It's never what's advertised.
RAACCR Sep 27, 2012 10:13 AM
Try calling Richard at West Coast Cylinder Heads (LS1Tech sponsor). He machines the Edelbrock castings; you can get them with 74cc chambers using HIP'd castings which makes them very durable for forced induction applications.
koolrayz Sep 27, 2012 10:41 AM
They also carry All Pro heads
TurboS10 Sep 27, 2012 01:30 PM
ProComp are 80cc IIRC. Not that I'd use them for FI...
For FI, you can get Cometic's w/ thicker compressed thickness, they won't cause detonation issues like they would in a NA setup.
stevieturbo Sep 27, 2012 01:37 PM
How big do you actually want/need ? and why ?
93camaro_zzz Sep 27, 2012 01:43 PM
Just curious why you are looking for something larger than 72cc?
I built my engine with low compression pistons, 72cc AFR's, and Cometic gaskets, and I managed to only get 9.06:1 static compression out of it. But in hindsight I really wish I wouldnt have done that, because now I am going single front mount and E85, and that 9:1 compression is not good for either one of those. Wish it was more in the 10.0 - 10.5 range.
stevieturbo Sep 27, 2012 01:48 PM
Just fit new pistons then ? Or use lots more boost.
LS6427 Sep 27, 2012 10:49 PM
Well, my AES 390ci is on its way to me right now. I had them buuild it with 10.8:1 cr......with flat top pistons, so I won't have such an N/A dog for the next 8-9 months.
Then when I install the turbo in 8-9 months I'll be using full time E85 fuel for sure but still wanted to lower the compression a little bit when I get new heads. My heads now are 69cc so I need some larger chambered new heads to drop the compression. Using LS9 head gaskets.
I don't want to do a piston change later on...........
I plan to go 18psi......single turbo....E85. 100% street car. Will never see a drag strip.
stevieturbo Sep 28, 2012 04:19 AM
So are those pistons in it now suitable for boost ? Or are they a n/a piston ?
The two are not the same.
And having driven my own n/a when I first put it together a few weeks ago. At around 9.0:1 it could hardly be described as a dog. It drove superbly and went far better than I expected.
LS6427 Sep 28, 2012 02:02 PM
Pistons are flat top and made for boost. I figured on E85 and 10.3:1 I'd be safe from detonation and get a faster spool.
I should be 10.8 right now......going from 69cc up to 72cc will give me 10.3:1 cr. if we figured right.....
69cc heads
.051 gaskets
Flat pustons
3.825 stroke
4.030 bore
LS6427 Oct 6, 2012 05:06 PM
Anyone else know of larger cc thick deck heads than 72cc?
Or can chambers on 72cc heads be worked and made to be larger than 72cc???
© 2026 MH Sub I, LLC dba Internet Brands
