LS6 heads and a stock 5.3 compression ratio I am wanting to turbo my car( 99 Ls1 Camaro) but if I do ill pull the stock ls1 out so I can forge it down the road, but until then I would like to pick up a 5.3 and put in it and turbo it, looking for around 6-700 rwhp, I would be using I TC78 mm turbo, 224/228 .581/.588 cam, Fast 92, and I already have a set of PRC Stage 1 ls6 heads and I believe there milled to around 62cc(bought them used) and GM MLS gaskets, what would this put the compression ratio on this setup, would it be too high for boost? |
Can anyone give me there thoughts? |
run E85 and dont look back |
Assuming you have the dished piston 5.3 and a head gasket thickness of .051?, that would put you at 9.6:1. I'm no turbo expert but I believe you can boost it with not problem. If the head gasket is the .061 then you'd have 9.4:1 even better. Yesterday I was shocked to see a guy boosting his 11:1 Camaro on youtube... |
Do a Google search for compression ratio calculators. Make sure you pay attention to your effective compression too (includes cam timing.) |
Originally Posted by AGearHead4Life
(Post 16863864)
Originally Posted by 91sonomast
(Post 16864757)
That's not a big deal IF he had forged internals. |
(Post 16864757)
That's not a big deal IF he had forged internals. YouTube: http://www.youtube.com/user/nitroused383 |
I have a stock bottom end boosted 11:1 compression ratio car. No problems thus far. Running E85 |
Originally Posted by PewterZCar
(Post 16864789)
I've got about 1500 miles since complete and lots of races. |
(Post 16864889)
Wow, that is freakin awesome! Technology kicks ass! |
Do a Google search for compression ratio calculators. http://bookstoday.info/go/smile.jpg http://bookstoday.info/lo/sad.jpg |
My stang is 11.1 CR and I have been running 9lbs of boost to it for 30k miles on pump 93. No problems ever. I just checked the plugs the other day after 15k miles and they still looked good. Put down 620RWHP. With E85 lots of guys are making over 700 to the wheels on stock bottom end boosted. |
Okay thanks for the info, and yes ut would be s stock 5.3, but ill look up a compression calculator! |
© 2024 MH Sub I, LLC dba Internet Brands
