TC78 on a 4.8/5.3- Horsepower/Backpressure
So I just bought a TC78 from Huron about 2 weeks ago and then I saw the thread about the bigger wheels available soon.
Sooooooo, with that being said I'm building a budget JY turbo set up for my fox body- The goal will be 140mph trap speeds and maybe a high 9 slip but its mainly a fun street car/Sat night car that gets beat on.
I know the 76/75 from Turbonetics or PT will make a ton more power with the bigger wheel but with the smaller displacement of the 4.8/5.3 will I do ok with the 68mm turbine wheel.
the car will never see any other engines other (large CI) than the JY specials.
My personal goal is to make 665whp - that's what my nitrous 408 Windsor made that I pulled out and sold to do the LSx swap.
basic setup will be
4.8
TH400 with tight converter
TC78- boost undetermined
E85
0411 PCM with HP Tuners
The fox weighed 2800 with my 408/5 speed combo
basic setup will be
4.8
E85
Location: Home town Clive,IA current town FORT BENNING GEORGIA
backpressure shouldn't be a issue with the smaller displacement motors. my buddy is running 14psi on his 76mm ON3 turbo stock LQ4 and just ran down a 681rwhp cobra lastnight. He had to turn his boost controller up a decent amount because he is having BP issues with the small turbo and bigger cubes. Car only makes 10.5psi on a 13psi spring.
You'll do just fine with that setup. I had a 76mm with a 96ar exhaust housing on a 4.8 and it ran great and made plenty of power. It spooled a little slower than on my 383 it was on but still did fine. Just boost the hell outta of it !!!! To make up for the lack of cubic inches.
LS1Tech Sponsor
TC76 or 78 should work awesome with a 4.8 or 5.3l, terrific turbos!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
LS1Tech Sponsor
Terrific!
__________________
Just saw this- it only made 570ish blowing thru the converter- I had it tightened up and haven't re dynoed-
ricer calculators says 620-640whp to go 143mph
just got a 3 bar map sensor- debating on getting a retune with HP Tuners at 21 psi or Switching to MegaSquirt and a Borg S478 Turbo and make more power with less boost.
