LSx turbo mustang 8.93@157!!! stock 6.0 with unported L92 heads holley hi-ram intake garret budget gt91mm turbo 18psi car weighed 3050 with me in it 8.93 pass http://www.youtube.com/watch?v=xpK8g...ature=youtu.be another pass http://www.youtube.com/watch?v=7Wken...ature=youtu.be http://imageshack.us/a/img822/4120/893157.jpg |
Nice. Thats enough mph for 8.60's when you get the front half figured out. Great mph. |
thanks! i think i can get it sorted out. this was the first time out with a new rear suspension setup. need to get the stupid 90/10 shocks off the front and replace them with an adjustable shock. |
Sounds a lot like my setup in my 02 Camaro. Runs great doesnt it? |
Originally Posted by Stangkilr
(Post 16902704)
care to share any more specs on the turbo? and whatre you running for a trans? |
you cut a 1.29 60ft on that pass against me right? |
Originally Posted by 1988montecarloss
(Post 16902752)
(Post 16902752)
care to share any more specs on the turbo? and whatre you running for a trans? its just a th400 with a brake and rmvb.
Originally Posted by 6.0mustang
(Post 16902786)
What size tire and gear? Picked up 34mph on the back end which is moving. |
3.55 gear and a 28x10.50 M/T |
Originally Posted by AutomagicLS1
(Post 16902806)
the gt91 is a budget $1300 turbo from forced inductions. I ran their gt-88 for a couple years then upgraded. They are a pretty nice piece
Originally Posted by dudeman
(Post 16902886)
its a t6 flange 91mm compressor wheel, 94mm exhaust wheel with a 1.08 ar its just a th400 with a brake and rmvb. yes sir. best one of the night. to bad it got loose that run. |
(Post 16902935)
thanks guys, are you still running the stock cam? |
More specs on the engine lq4, lq9, rod bolts, studs, gaskets? |
Originally Posted by 9sectruck
(Post 16903014)
More specs on the engine lq4, lq9, rod bolts, studs, gaskets? LY6 motor. it has ebay $60 head studs and ls9 gaskets. i did pull pistons out and open the ring gap. i reused rod bolts. it has a stock oil pump. it does have a moroso deep pan. |
(Post 16903045)
LY6 motor. it has ebay $60 head studs and ls9 gaskets. i did pull pistons out and open the ring gap. i reused rod bolts. it has a stock oil pump. it does have a moroso deep pan. Do you have any pictures of the set up? How are you running the exhaust? Also, are you using Hptuners, stock pcm, stock wiring harness? |
Originally Posted by Wicked69
(Post 16903143)
Wow....that is amazing! What fuel you running? E85? I am curious what others think about your cam choice. I run a pretty good size cam also. Seems that everyone always wants to run a "smaller" cam on the turbo's but yours seems to love the bigger cam. I would love to hear a video of it just idling in the driveway if you have any. Do you have any pictures of the set up? How are you running the exhaust? Also, are you using Hptuners, stock pcm, stock wiring harness? no idle vids. http://imageshack.us/a/img600/3327/hotside.jpg the exhaust is shorty truck headers flipped with v bands welded on. 2.5 cross over. 5" dp split into two 3" pipes that run back through the k-member to the firewall and then turn down. |
(Post 16902944)
no, it has a 232/240 .595/.609 115lsa cam in it |
that cam has 6deg of overlap in it is there any back pressure issues with that cam? what did you torque the head studs down to, I have used the ebay studs up to 22psi of boost on my built ls2, but im pretty sure they where torqued to 75ft, what did you do? |
(Post 16903570)
© 2024 MH Sub I, LLC dba Internet Brands
