eBay gt45, stock 4.8, goes 9.18@146
Hey guys figured I would post a thread with updates. We have one last chance to get the car out this weekend. The above was at 17.5 psi due to boost controller issues that we believe we have figured out. The above was also on a 3.91 gear causing the car to really nose over on the big end. It will be on a 3.54 gear this weekend. I'm sure the gear alone should make a big difference.
Stock 4.8 with stock 243s
Patriot golds
Ls6 cam
Ls1 intake
eBay Gt45
Stock 240sx rear and axles
Th400
Tuned on hptuners by dkgoodrich
Timeslip
Video
Big thanks to my engine guy: Robert@ Roberts performance machine in lexington, ky
My fab guy: Andrew Dimartino@ Dimartino fabrication in lexington, ky
And my tuner DK Goodrich dkgoodrich.com in Frankfort, ky
Patriot golds
Ls6 cam
Ls1 intake
eBay Gt45
Th400
Timeslip
Video
no dyno numbers with the current setup. on the 6speed we saw 686 at 14psi with fairly conservative timing. The car has been 148 on the 6spd with a best of 115 in the 1/8th. Now we are picking up so much in the 1/8th that we are out of steam on the big end, hoping the 3.54 gear keeps the car in the fat part of the band.
limiter is at 7500 we are crossing the line in the 7300 area. Shifts are usually in the 6900-7000 area. with the new gear ill probably shift at 6500 as the rpms are only dropping about 8-900 on the shifts.
