How many of you guys run your oil feed off the oil pressure sender?
As the tittle ensues, how many of you guys run your oil feed off where the oil pressure sender is located? I know about the spot you can tap into by the oil filter and planned on running it from there but since my turbo is located on the drivers side i was wondering if the oil sender port would work for cleaner routing.
I run mine turbo feed off the stock oil pressure sender hole, it works fine, I moved a aftermarket sender down by the oil cooler ports for a gauge. I figured the line was shorter but there is no real advantage thought, just a different way of doing it.
