How to Microsquirt fuel and spark your LSX swap (sloppy mechanics how to!) 8-10-13
Old 03-01-2013, 12:19 PM
  #61
Moderator
denmah's Avatar
yeah i was getting alot of questions about the flashing and whatnot proceedure, people were willing to do everything but they were intimidated by this part, so this should show that it isnt that bad!
Old 03-01-2013, 01:07 PM
  #62
tta656's Avatar
http://www.ebay.com/itm/Radio-Shack-...2103%26ps%3D54
Matt maybe you need this...
Old 03-01-2013, 02:21 PM
  #63
Moderator
denmah's Avatar
oh i have 12v adaptors, from laptops and whatnot, and i do use them on the megasquirt stuff sometimes, but this particular one i wanted to test the ecu on the sensors and whatnot on the motor before i shipped it out to someone, so i just did it on the motor.
i have never had a problem flashing and testing and even running the motors with the charger only, i understand the voltage moves around alot and the battery is better.
Old 03-01-2013, 06:16 PM
  #64
aknovaman's Avatar
That eBay charger is way over priced.
I use these:
http://www.ebay.com/itm/12V-5A-Power...item1c2de76468
Old 03-20-2013, 03:22 AM
  #65
jprince's Avatar
"for the TPS and MAP sensor you will need to split the 5v reference, and then connect it to the TPS'
could you explain this lol... and the remaining wires on the micro ie. pin 13,14,15 etc they tied back?
amazing write up!!!
Old 03-20-2013, 11:26 AM
  #66
stacy moore's Avatar
Can i just flash it on the bench with my desk top computer after i do the mods inside the microsquirt (the 3 wires/resistors) before i hook up the harness in the car?
Old 03-20-2013, 11:32 AM
  #67
aknovaman's Avatar
Yes, bench flashing is same as in vehicle.
Old 03-20-2013, 11:59 AM
  #68
chris406's Avatar
amazing write up!!!
I have the same question. Also want to confirm that this works with high impedance injectors only? How do I use my LM1's wideband O2 with this?
Thanks
Old 03-20-2013, 12:06 PM
  #69
aknovaman's Avatar
Tps and map both need connected to micro +5v reference wire. Look at the basic Microsquirt wiring diagram. Google Microsquirt wiring diagram for picture
Old 03-20-2013, 03:52 PM
  #70
Moderator
denmah's Avatar
Ill be back Friday and read and answer haha too hard on the phone
Old 03-20-2013, 09:45 PM
  #71
jprince's Avatar
10-4 see what u meen now with the tps and map need to be spliced together then ran to the 5v ref.
Old 03-21-2013, 07:39 PM
  #72
Moderator
denmah's Avatar
well both sensors need 5v,
so that is the wire you split, you just add another connection.
the signal wire is what goes back into the ecu.
the 5v wire goes to the power 5v+ on both sensors, then the signal wire for the tps goes back into the ecu, same with the map sensor signal wire, after that both of the grounds can be paired or shared also.
Old 03-22-2013, 11:41 AM
  #73
chris406's Avatar
What about larger injectors, will they cause issues. The only comment I've seen made is that with larger injectors the idle will suffer at lower RPM. Coming from a blow through carb like I am I'm not to worried about that Would 96lbs injectors cause fits?
Old 04-12-2013, 01:06 PM
  #74
Moderator
denmah's Avatar
just got a PM from a member on here that he is running a 58x motor with the microsquirt successfully!
Old 04-18-2013, 08:06 PM
  #75
1fastpickup's Avatar
What do you use for o2 in these setups...I see EFI Source sells these with an o2...but narrow band...is that what you are using for O2? I have a wideband now is anyone using one in conjunction with a microsquirt?
Old 04-18-2013, 08:08 PM
  #76
aknovaman's Avatar
Microsquirt can be configured to accept any wideband input.
Old 04-18-2013, 08:21 PM
  #77
Moderator
denmah's Avatar
i just wire in the AEM UEGO into all my setups, i like it
Old 04-18-2013, 08:50 PM
  #78
Zerex's Avatar
Do you think someone will sell packaged units with everything needed including a base tune?
Old 04-18-2013, 09:14 PM
  #79
Moderator
denmah's Avatar
we talked today about them modding the ECU ahead of time.
not sure if they will build a harness,
he sells the kit to do it yourself, but looming and tooling a harness is really expensive and most people do not want to pay for that.
i think they are going to build a plug and play harness for the Ms3 ecu and have a wire yourself harness also
Old 04-28-2013, 08:47 PM
  #80
regaltutt's Avatar
has anybody done 2 microsquirts wired together one controlling 5.3 and another for a 4l80e
Quick Reply: How to Microsquirt fuel and spark your LSX swap (sloppy mechanics how to!) 8-10-13
