Looking for pulley size input and belt options 8 rib setup Revisiting this as my setup went from a D1 to and F1C Setup: 5.3L Truck motor 5.3L 799 Casting with intake gasket match, deck and valve job Tick Performance Custom Blower cam package Procharger F1C with ????" pulley A&A 8 rib bracket with Procharger 8 rib pulley's Innovators West 10% OD balancer Custom piping to Treadstone intercooler Custom fuel system for E85 SD 80lb injectors flow matched I am looking for help on pulley size/boost levels and what my belt options are. Looking at the impeller calculator probably looking at: Crank Pulley 8 Blower Pulley 4.25 Step up Ratio 5.4 RPM-Engine 6400 Impeller RPM 65054 or Crank Pulley 8 Blower Pulley 4 Step up Ratio 5.4 RPM-Engine 6400 Impeller RPM 69120 F1C has 74000 RPM max, and I am not looking to max it out. Leaning more towards 4.25. I will be running the 5.3L truck motor with a cam package spinning it to maybe 6400 or a little more, as I want it to live for a while. I will be running E85 and am looking for stout power numbers(would be happy at 650whp or above) Any help appreciated. |
So what size is the crank pulley? With E85, your probably safe to low 600rwhp for a while if the tune is good since the burn from E85 is considerably cooler than gasoline (E10-15). Biggest issue with a stock motor is ringlands being taken out by factory rings. So I'd say if your crank pulley is ~7.6-8.1", I'd run a 4.25" pulley to get about 10psi at 6500rpm. Obviously depending on the intake and exhaust setup as well as cam choice. |
bumping for more input and setup change |
Originally Posted by b16gsr
(Post 17335501)
Originally Posted by helga203
(Post 17336119)
As you now me from the other forum. I ran a 3.85 top and 8"bottom that's perfect to 6500 to 6600rpm 74 to 75k impeller speed. Perfect fot the f1-c.:hump::hump: I have an 8 rib 3.85 laying around. Don't need anymore since my next step will be F3. |
(Post 17338775)
Sure do my friend and thanks for posting. I think that the 3.85" top is more than I want to do. I have decided on the 4.25" to start and see where it takes me. |
© 2024 MH Sub I, LLC dba Internet Brands
