Out of curiousity why does everyone use 2.5" on the crossover pipe
#261
We know that 10 lb/min air flow is about 100 hp. So, if you're making 1000 hp, you're flowing about 100 lb/min (both into and out of the engine). You would need to divide this mass flow rate by density to get volumetric flow rate. Density is calculated using P=pRT, or p=P/RT (assuming pressure = 2-3x your boost level if you don't have a measurement and T = 1600-2000 F). Convert all the units and you should wind up with an exhaust volumetric flow rate that you can convert to velocity pretty easily. Don't forget that only half of the flow goes through the crossover pipe.
#262
So does too large of a crossover just slow down spool time? or are there other problems?
I ask because I had mine made with 2.5" (before I found this thread) and I can build pretty much as much boost as I want antilagging at the line, and all hell breaks loose immediately. If I couldn't antilag, I know I would have spool problems though.
#263
I am not having spool problems on my little 5.3 with 2.5" divided flange set up. I have 2.5" going to each side of the turbo which has a 92mm turbine and a T6 1.10 ar turbine housing. Not ideal, but was what I had at the time and what I used. Currently pushing against the brakes by as low as 2800 rpms I am building boost and breaking the tires loose or if they are warm I am pushing through the front brakes. While I hope to build and compare one day using schedule 10 2" pipe (think it is around 2.15 ID vs my current 2.35) for now I am running the 2.5 piping. I don't think you have a lot to worry about Cameron.
#264
I just ordered all the stuff from columbia mandrel to build my hotside with truck manifolds and 2 1/4", pipes, using mild steel but will be sent off for coating, system will be twin scroll with twin Tial F38s, feeding a S480 with the 96mm 1.32 A/R housing, 5" downpipe exiting out the passenger front bumper. Motor is a forged 6.0 with a Tick Cam, ported 317s and a LS6 intake keeping it simple. Will post results/vids as I have them I expect to have it up and running in about 2 months.
#265
Here is a good example of what 2.5" piping is capable of.... I know it's not a perfect example because it's a twin setup. Still, he is using 2.5" collectors on the headers. Also necked down the turbo outlet piping diameter and uses a smallish throttle body.
6.27@ 228mph "fastest run a Pontiac V-8 ever made"
2800hp
10:1 482ci @ 7200rpm
40+lbs of boost
Twin 91mm turbos
90mm throttlebody
Hotside
2" primaries to 2.5" collectors
2800hp
40+lbs of boost
Twin 91mm turbos
90mm throttlebody
Hotside
#266
I love these kinds of discussions. I can't even tell you how many times I've read through Maximum Boost and Scientific Design of Exhaust and Intake Systems. Everything here is basically putting these into practice and why we build these things.
#267
I have a 3" crossover and haven't noticed any issues with spool I've had tuners say how impressed they were with spool on my car but then again I have a nicely sized turbo for the motor so that might be why. Anyway, yeah I'm just putting it out there that it seems to work for me and my setup. I also have the stainless works headers that have a 3" collector.
#268
#270
But I get your point, it would pretty much be your setup...
#275
I can give you several names of turbo cars with the same size or smaller engines that have been faster than the car posted, eg
andy jensen
dal sangha
but all that would prove is that we are both in la la land arguing about stuff that has no bearing to what 99.9% of people here will ever do so ill give you examples that are more inline with this board.
3" merge, 355 sbc, 3600lbs,s480 1.32ar
no boost issues here
http://www.youtube.com/watch?v=6Miw9...ature=youtu.be
3" merge,331ci, pt91,1.0ar, doesnt seem lazy to me
the merge
the pass
and whats more interesting, both of them had trouble spooling with the wrong converter, but no issues spooling with the right CONVERTER.
back to you.
andy jensen
dal sangha
the merge
the pass
back to you.
#276
didnt we have a guy on here in a black trans am that built his car, bigger turbo, 91is? on a 370is motor that had alot of trouble spooling and then he rebuilt the kit to a 2.5" kit and all his spooling problems went away?
Just last year?
Just last year?
#280
https://ls1tech.com/forums/forced-in...e-12-10-a.html
And here is the 2.25" crossover
https://ls1tech.com/forums/forced-in...e-06-29-a.html
