C6 Corvette build - ProCharger F-1A / 365ci / LSA / E85 [*UPDATE* 915whp/815wtq]
Old 02-22-2013, 10:27 AM
Realcanuk's Avatar
Great build and great documentation. I am in the process of a C6 build myself and its nice to see this. I wish I had the patience to document mine so well. Did I thank you for inspiring me ? I ordered almost the same wheel setup you are running. Those pics of your car are just awesome.
Looking forward to see the final results... keep up the great work.
Old 02-22-2013, 12:24 PM
Detoxx03's Avatar
Not to thread jack but what's the progress on yours? I wanna see what that eforce can do.
Old 02-22-2013, 12:31 PM
turbotuner20v's Avatar
Thanks
The weld RTS's are popping up on vettes everywhere now... it's a great wheel option to get some decent tire under the car.
Old 02-22-2013, 01:01 PM
Realcanuk's Avatar
Not to participate in your thread jack .... but.... I just recieved my engine. I will slowly put things together over the next month. No rush as there is snow on the ground here. I overbuilt the engine thinking something different next year but want to max out that eforce first, to see what it can do.
Old 02-22-2013, 01:38 PM
Detoxx03's Avatar
Coming to the centri side???
Old 02-22-2013, 01:40 PM
Realcanuk's Avatar
Blasphemy !! I dont know. What I have will probably be enough, but I have to do something next winter or I'll be bored.
Old 02-22-2013, 03:28 PM
TheLS1Lover's Avatar
Could you teel me how the fuel system works a little more? Are there 3 pumps all together (1 in each tank, and the MP4303) or what?
Old 02-22-2013, 04:56 PM
Stangkilr's Avatar
Awesome Jeff!
Old 02-22-2013, 05:49 PM
The stock system has a pump in each tank. The passenger pump just moves fuel over to the driver side tank, and the driver side pump feeds the rail. I tapped into the stock in tank pump on the driver side and it Y's into the -8 feed line to the rail. This runs solo under 4 psi, just like stock pretty much. Above 4psi the magnafuel 750 turns on and both the stock in tank pump and the external feed the rail. Then I have some short runs connecting the regulator return to the stock feed hard line, and to the tank return bulkhead. Should keep the fuel cooler and not need a pump controller.
Old 02-23-2013, 09:48 AM
Thanks for clearing it up! Thats what I though, just wasn't positive.
Old 02-23-2013, 10:47 AM
j88l98irocz's Avatar
Very nice detailed build!
Old 02-23-2013, 02:49 PM
  #32
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Extremely nice build and very well documented. How long did it take you from when you started to where you are now?
Old 02-23-2013, 06:23 PM
  #33
First pic on the rack is 12/4/12
I lost about ~3 weeks ditching the ls3 heads and buying the lsa from summit (back order, plus they sent me 1 ls3 by accident). Then I decided to port them.
The goal is tx2k, so the work schedule has flexed with that as the deadline.
Old 02-24-2013, 11:07 PM
  #34
swapped the front shocks... DRM valved Bilsteins all around:
reinstalled the shifter assembly and interior:
added fluids
Also installed the tunnel plate, headers, spark plugs and coil wires.
Soooo close... looks like it'll be good to go for first start next Saturday for sure. Hopefully all the snow up in KC has melted by then so I can take it for a quick drive too.
Old 02-24-2013, 11:30 PM
  #35
conan's Avatar
Very nice build sir.
Old 02-27-2013, 11:12 PM
  #36
Finished installing the exhaust and went over everything one last time.
I cranked it over a few times with the fuel pump relay pulled and the coils disconnected and everything seemed to turn over fine.
I plugged the relay back in and turned the key on and the stock fuel pump primed and the gas gauge registered the 5 gallons I added, so that was good.
I also jumped the connections on the Hobbs switch to test that the magnafuel external ran, and it turned on as expected as well.
My tuner should have a base tune ready for me in the next few days to fire it up with.
Old 02-27-2013, 11:54 PM
  #37
Detoxx03's Avatar
Nice to hear its almost done. Who is tuning it?
Old 02-28-2013, 12:12 AM
  #38
Lightbulb
Justin Kalwei
Old 02-28-2013, 12:26 AM
  #39
Detoxx03's Avatar
I know who you are talking about.
Old 02-28-2013, 07:41 AM
  #40
MertezWS6's Avatar
Very nice car, build, and garage! subscribed for some vids and results
Quick Reply: C6 Corvette build - ProCharger F-1A / 365ci / LSA / E85 [*UPDATE* 915whp/815wtq]
