Best Meth Injection Kit?
Best is all relative to the hear say bs on most forums. I run the cooling mist setup because I am a tight wad and my cars go fast for cheap. Its under $300 on eBay. Sure, if you are wealthy and like to spend money then by all means, drop the coin on a more expensive setup.
He runned Boost Juice which is Snow's proprietary mix of 49% methanol and 51% water for a while, and he said he did see some gains but he decided to just run 100% VP Methanol for better results on 93octane. I dont know what supporting fuel system he running soo that I wouldnt know, he claimed to have gotten impressive gains. The pump is still running strong and hasnt gave him a problem. Some might think im BS but I dont lie behind the screens and make stuff up to make people believe me, im just giving honest info to help someone out.
Have a few friends that run snow and after having nozzle issues and a pump going out they all plan on switching to Alky after seeing the quality of my kit. If you plan on running 100% meth snow isn't the kit for you that's for sure. They recently had a recall issued.
http://forums.corvetteforum.com/c6-f...ce-recall.html
Thanks for that link Detoxx03... Will have to give them a call.
Edit: Well I just gave them a call and they didnt hasitate on helping me out and giving the info about what should I do in case I do have that bad valve they are recalling and replacing it with the right piece under the same warranty.
#36
I used to recommend AIS (alchol injection systems) but won't any more. I've sent email and called with no response. I like their product but have been lacking on customer service as of late.
#37
i cant say its the best kit on the market since i haven't used all of them, but so far my AEM water/meth kit has worked great and never let me down.
i purchased the AEM because of there pump. its a 200psi pump that they claim is compatible with 100% methanol, so a 50-50 mixture shouldnt be a problem. The boost sensitive controller also is nice because i can control exactly when the pump begins to turn on and when it should be at peak flow. Theres also a warning light that blinks a 'morse code' to let you know if you're low on fluid or if there is a failure in the system. Also AEM offers a lot of accessories for an additional price. Personally i'm just running the basic kit and have no regrets.
that being said, i have heard good things about aquamist.
#38
UNDER PRESSURE MOD
That's where I got mine from and they are great. I'm running the HFS-3 setup.
#39
http://howertonengineering.com/produ...ection-system/
