ON3Performance No A/C Ls1 Camaro REVIEW PICS VIDEO GREAT KIT!
#244
I'm looking into getting this kit as well and I'm just wondering if all over the tubing fit in the car without getting a k-member. Also, it looks like you used the stock manifolds and just put some covers on them, I'm guessing the kit doesn't come with manifolds? I'm just getting as much information as I can so I can get all the parts together. Thanks guys
#245
All the piping fit great woth the stock k member. The kit does come woth manifolds bit i used flippes TRUCK manifolds because i did not want emissions stuff on it. Pm me if you have anymore questions and i can answer just about any question you have.
#249
The 2.5" piping crossover is more than big enough, without being too big. To get more clearance on this kit you could always stand up the radiator too. I dont think the on3 88mm turbo is out yet, but that may be a tad on the larger side for a streetcar with a 347 with an m6. Best bet would be have someone like martin at tick or lil john to spec you out a cam/turbo. The heart of a turbo car is the turbo that largely dictates the rest of the set up.
#251
Probably their 76mm but its limited as the exhaust wheel is only 65-66mm I think. It will spool fast but itll be choking you on the top end so youll need to run a large ar exhaust housing. Youll make at most 650-700 on that turbo but your displacement will keep it from being as efficient as it could be. For a 5.7 something like a turbonetics 7875 or a precision 76/75 would be nicer as its got a 75mm exhaust wheel so itll carry power further into the rpm range without running a big ar housing hurting spool time. Those turbos maxed out will get you 700-800+ and will spool pretty well with an m6 and appropriate cam.
On an m6 car that 88 is gonna need a two step to spool well for launching under boost, imo you need an auto trans to make a good street car for a larger turbo.
#252
#255
Its going to work just as well as the other 2 turbos being discussed to use in the previous posts, 7675 and 7875. Its an 800+ wheel option, we have guys already in the 720-730wheel range with just the 7665 option
#256
Physically is it much larger then the 76 on3 turbo on the compressor side?
#257
Too bad that wasnt available 6 months ago or Id have gotten that. The sbe ls1 is the weakest of the stock bottom ends, make sure to run e85 or meth injection with 93 to help it live. Youre safe to about 600whp reliably other have gone higher but the tune needs to be spot on. Any hint of detonation on any motor is gonna end badly with boost in a short time.
#259
I've got one customer that made 800rwhp with one of the On3 76mm turbochargers.
It did not have the 75mm turbine wheel, it had the smaller turbine wheel.
It was on E85, had 10:1 compression, stock heads and stock intake. Had a very unique custom grind with 12 degrees of intake to exhaust duration split and 0 degrees overlap.
I have not seen one make more power than his. It almost made as much torque as it did rwhp.
