ON3Performance No A/C Ls1 Camaro REVIEW PICS VIDEO GREAT KIT! 14 Attachment(s) Im going to try to do this as best I can but its my first time doing a write up so be easy... lol Ok, Ordered an On3 no a/c kit for an 02 camaro with and upgraded 76mm journal bearing turbo and a 4" intercooler upgrade as well. When it came to the house (only took 2 or 3 days!) I opened the box and was amazed at the quality I got, especially for such a low price. Stainless polished hot side pipes are a thick guage steel that are heavey enough to know they are not some cheap junk that would fall apart but, at the same time not so heavy that you are adding a thousand pounds to the car. Cold pipes are a nice light polished aluminum that seem to line up great and seem to be of good quality. As of this time right now my only complaint (if you would even call it that) is no instuctions. But it has been pretty simple to figure out. Also as of right now the kmember and drivetrain are out of the car because we also did heads and cam on this car as well as a monster stage 4 clutch package from Tick, a 9" from (cant say name because they are not a sponsor, For details pm me). Here are the pics I have so far of the kit and more will come. As of right now there is nothing I feel I need to describe because the pics are self explanatory but if anyone has any questions by all means let me know... Attachment 609784 Attachment 609785 Attachment 609786 Attachment 609787 Attachment 609788 CLOSE BUT STILL FITS WITH NO NOTCHING OF THE K MEMBER!!! Attachment 609789 Attachment 609790 DOWNPIPE FITMENT IS GOOD Attachment 609791 Attachment 609792 Attachment 609793 Alternator bracket was a little trick with no instructions but was fine as soon as you look at it for a few minutes. The part of the alternator that actually bolts to the head is a stock bolt reused but all other hardware and spacers and such are provided... Also the single 18g wire that clips into the alternator can be re routed through the harness to the passenger side. Some people will probably just cut it and run a new wire but I like stuff to look as clean as possible and have a stock look so I ran it all back through the harness and came out where the A/C lines used to come out at the end of the injector harness. I hate using anymore splices than I have too. Attachment 609794 Attachment 609795 Attachment 609796 Attachment 609797 I am on a very tough time scedule for this build so this may take a little time to get on here and do the write up, but I know a lot of people have questions about this kit and someone has to step up and help out. I have gotten so much from this site and it is now my time to give back. So like I said bear with me I will try to get this done asap and as organized as I can but I just want people to have a source of info on this phenomenally priced kit. |
This build is on my buddy Joe's car his name on here is JTblack02SS its a super clean 30k miles ss that is immaculate. Or at least was untill it got inhere and go filthy and covered in dust lol. |
looks good did the oil feed block come standard or did you ad it on to the kit |
No that was also an upgrade. Sorry forgot to mention that they were $39.00 and are a very nice quality piece. |
yeah I was also thinking that. Thanks |
Originally Posted by 1999Black_Z28
(Post 17227844)
You might want to relocate that brake line to the bottom of the k-member to keep it away from the heat. |
Build looks good keep it coming |
Originally Posted by c0ncEpT
(Post 17227990)
Not only that but if you don't notch that K-member now your going to play hell with that bolt if you ever have to take the crossover off. |
just put the spark plugs in and everything was good except on the drivers side back plug I had get the dremel and take off about a milimeter at the most off of one tiny part of the manifold to fit the socket in but all is fine now. just thought I would share that in case someone is putting it all in while the motor is in the car, you may wanna do it before the manifold goes on. I will put a pic up when I get a chance to take one... |
build looks good so far, the pics answer a few others questions I was going to pm you about lol |
Glad to help. Thanks. Talked to Adam today who is a great guy to deal with by the way. And just so everyone knows the waste gate springs included with the kit are for 7 psi. |
how did you do the Turbo Oil Drain? Into the Pan or timing cover? Did you drill and tap it on the engine. And are you running a scavaging pump? |
We arein a hurry so for now we are just draining it to the oil cap with a 10an oil billet oil cap from ebay but will eventually go to either the pan or timing cover. And yes we are using a scavenge pump. You may be able to get away with out one but the turbo looks like it sits a little low to really drain good so we went with one just to be safe. |
Yeah i plan on running one since ON3 recommends running one. Just trying to get an idea how its going to run for when I order my kit. |
Matt thanks for posting up your build and photos to support what you are doing step by step. Im finally back at the shop so if you have any other questions, just shoot me a message and Ill be back at it each day.
(Post 17227990)
Originally Posted by evilz99
(Post 17238582)
We arein a hurry so for now we are just draining it to the oil cap with a 10an oil billet oil cap from ebay but will eventually go to either the pan or timing cover. And yes we are using a scavenge pump. You may be able to get away with out one but the turbo looks like it sits a little low to really drain good so we went with one just to be safe. Although its really expensive, we can get you an oilless turbo if you wanted to completely get away from running the oil lines or pump. |
Nice build thinking about pulling the trigger on this kit also |
(Post 17231294)
yeah they seem like great guys. I have been working with them a lot to try and make small suggestions and help out as much as I can and also for troubleshooting and they have been very helpful. |
Originally Posted by On 3 Performance
(Post 17241399)
Matt thanks for posting up your build and photos to support what you are doing step by step. Im finally back at the shop so if you have any other questions, just shoot me a message and Ill be back at it each day. |
© 2024 MH Sub I, LLC dba Internet Brands
