1 hole or 6 hole tip 95lb injectors???
Im getting ready to order the FIC 95lb high imp drop in ls1 injectors and they have 2 options...single hole tip or 6 hole tip. which one is better?
My setup is
383 ls1
317 heads dual springs
holley hr intake
239/244 .612/.598 115+5
BEP 91mm tubro
4l80 3300 stall
My thinking is 6 hole would atomize better?? is this true? I post over in the fueling section but I was thinking more replies in the FI section for the size of the injectors and being that its a turbo setup....thanks
My setup is
383 ls1
holley hr intake
BEP 91mm tubro
4l80 3300 stall
Years ago I used to think the multi-hole provided better atomization - not so much anymore.
After futzing around with several different injectors/injector delay/dyno and fixing high HP car drivability problems by switching to single-point injectors I'm a believer in the single spray (ie. lazer beam) pattern. I think you get better atomization because you are impinging the fuel flow off of the back of the intake valve into the cylinder.
The fan style I think you end up with more impingement on the head wall and thus overall worse atomization.
