LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   Catch can drain back to oil pan Do or Don't?? (https://ls1tech.com/forums/forced-induction/1662465-catch-can-drain-back-oil-pan-do-dont.html)
khenry Jul 18, 2013 01:22 AM
Is there any reason I shouldn't run a drain back into my oil pan from the catch can. LSx 427 / Large frame T-6 turbo. First hand answers please, Thanks! [IMG]http://i1216.photobucket.com/albums/...ps50c48742.jpg[/IMG]
itsslow98 Jul 18, 2013 01:25 AM
No you will get condensation that forms in the can. You def dont want to contaminate the oil and then run it right back through your motor.
I8UR4RD Jul 18, 2013 02:14 AM
:judge: hail naw
LS1-IROC Jul 18, 2013 05:53 AM
Bad idea
SirNemesis Jul 18, 2013 06:00 AM
What about in the event of a sealed catch-can setup? Still a bad idea? Where does the condensation come from?
pwrtrip75 Jul 18, 2013 06:22 AM
The whole idea of a catch can or crankcase evac system is to pull/collect vapors from your engine, vapors include condensation thats accumulates just like the morning dew accumulates on your window. So draining it back into the pan would undo what you wanted it to do to begin with. When my car runs E85 I can dump out almost a quart of water in a month.
MUSTANGBRKR02 Jul 18, 2013 08:01 AM
As stated it's a bad idea.
Cam72aro Jul 18, 2013 08:06 AM
Ding ding ding. Words of wise right there.
SPRAYED 01 Jul 18, 2013 08:32 AM
Its would be easier for you to run no catch can then. You are defeating the purpose. On a side note, how necessary are catch cans? On my turbo car im sure oil temps are over 212. So wouldn't the water boil away? I have never run one,boosted for 4 years now and no issues. I just run open breathers
ls1_chevelle Jul 18, 2013 08:38 AM
The purpose of a catch can is to get rid of the mess of having breathers sweating onto things which become a fire hazard. Catch cans are just a more accurate way to collect the junk and prevent it from entering back into the engine.
HRHohio Jul 18, 2013 08:53 AM
This is what a typical catch can will capture. About 80% water (on the bottom), 20% oil. Depends on how much oil gets blown out of the line, but for the most part, the catch can is condensing the steam and combustion blow-by that gets past the rings and could contaminate the oil. Imagine pouring this back into your motor oil (i.e. drainback).
Not healthy for the motor oil/engine.
http://redlinemotorworks.files.wordp...oil-closer.jpg
Somebody09 Jul 18, 2013 11:43 AM
Originally Posted by HRHohio (Post 17554191)
This is what a typical catch can will capture. About 80% water (on the bottom), 20% oil. Depends on how much oil gets blown out of the line, but for the most part, the catch can is condensing the steam and combustion blow-by that gets past the rings and could contaminate the rings. Imagine pouring this back into your motor oil (i.e. drainback).
that's disgusting lol. i guess i should get one too
evo462 Jul 18, 2013 06:37 PM
Whenever I drain my catch can it's mostly clear, smells a little bit of alcohol or something. Could be e85. But yeah, definitely don't want that back in your oil pan ;)
stevieturbo Jul 19, 2013 07:51 AM
Been running mine like that for a few years with no issues.
The can itself does gather a lot of mayo, but it's certainly never caused any problems and is more down to the can being remotely mounted and being cooler than the engine itself actually causes the condensation to form.
Inspector12 Jul 19, 2013 09:29 AM
I dont do it, JMO.
LS6 Z28 Oct 25, 2013 03:23 PM
do any of you run 2 breathers on both valvecovers then run lines from both covers to a catch can?
speedtigger Oct 25, 2013 04:03 PM
The benefit of crankcase ventilation is to prevent the inside of an engine from becoming the pressurized and propagating leaks.
Positive crankcase ventilation induces a controlled flow pattern of: in through the breather and out into the intake tract. The benefits of this are preventing oil mess at the breather and to prevent emissions into the atmosphere.
The benefit of the catch can is to stop engine oil picked up in the positive crankcase ventilation from entering the intake tract. Engine oil in the intake tract leads to: fuel mixture contamination as well as valve and combustion chamber deposits that can cause reduced flow, and pre-ignition.
© 2026 MH Sub I, LLC dba Internet Brands
