Finally got to the DYNO
Old Jul 18, 2013 | 08:17 PM
11SECSS's Avatar
Default Finally got to the DYNO
Well after trying to get everything ready for the past 5 months I get to the dyno .The first base line run showed 429 rwhp with minor tuning issues then after some adjustments the seconf run showed 447 rwhp.Did some more fine tuning and the 3rd run the assy belt came off for some reason and tuner said the graph showed the belt was starting to slip around 6-8 lbs.So back to the drawing board to figure out whats up with the assy belt.
I was hoping to see 500 but maybe next time I get back with all problems fixed.
Old Jul 18, 2013 | 09:44 PM
conan's Avatar
Whats your set up, 6 rib, 8 rib, Stock j bracket, SDCE, Aster ???
I would also recommend getting one of these... http://www.qualitytoolsforless.com/P...FQE6QgodrH0AKg
I found my blower pulley was off 1/2 a rib and had to get a .050" shim from fastenal. I have never had the belt come off on me, so yours might be off quite a bit.
Old Jul 18, 2013 | 09:52 PM
camarochvy21's Avatar
That's a lot of coin for a alinement tool
Old Jul 18, 2013 | 10:15 PM
11SECSS's Avatar
My setup is a 8 rib with a 4.5" blower pulley and a steel stock Jbracket.Blower belt stays on its the factory accy belt having issues its never done me wrong driving on street just on dyno .Trying to get it all worked out before going to track to see if I can get into mid 10's.
Old Jul 18, 2013 | 10:49 PM
conan's Avatar
So the blower belt is slipping and the serpentine belt is coming off ?
Old Jul 19, 2013 | 03:25 PM
11SECSS's Avatar
Yes going to tighten up blower belt and borrow a buddies katech solid adjustable tensioner.
Old Jul 19, 2013 | 04:25 PM
conan's Avatar
You might want to throw on a new belt, once they slip its easier for them to do it again. I would also check the tension of the belt after a short drive and tighten it up again.
Hopefully the katech tensioner solves the serpentine belt problem.
Old Jul 22, 2013 | 07:48 PM
IllusionalTA's Avatar
Damn Joey stepping it up.. Keep me posted... At your weight 10's should be cake
