Anybody running stock fuel rails?
I am running twin 10 pound methanol nozzles with hundred percent methanol and 93 octane pump gas. holds 58 psi pressure just like a factory car. the only thing I changed was putting the two fuel pumps in the factory bucket and the injectors
Got no way of knowing my fuel pressure but it holds 11.0 a/f when at wot and when my methanol comes in it goes to 10.2 and holds. I know on 8psi when I had it tuned the injectors were only 35% duty cycle at wot lol.
And yes I guess you would call it a return system. But it returns through the evap. My setup should be good to 800 rwhp on lines and all. Many ppl have done it I have researched in past when I was getting my stuff together.
1 Post
So your using an external regulator and not the in tank one?
Skinnies, do you have pictures of this setup? I'm very curious. I was about to drop my money on a aeromotive fuel rail/FPR setup with -8 and -6 fuel lines but if you have this documented I would be very likely to try this setup on my 5.3 with a stage III Incon twin turbo kit!
