help, car starts but wont run
as it says, i start the car and it fires and runs for half a second but thats it. I started looking for all the grounds to make sure that i have them in order, 3 on the back of the head, 2 drivers side kick panel and 1 passenger side kick panel. Its getting plenty of fuel and pressure, pump is new and repaired bad fuel fitting at the rails and with the key on more than plenty of fuel is spilled everywhere. I have a 3 bar map sensor in it and no mass air for tuning but nothing has been done yet. wanted to start it get the trans filled and make sure I have no exhaust leaks and make sure everything is in order before heading to the dyno to tune it. could it be the lack of MAF and the 3bar MAP keeping it from running? any help is appreciated
Dan
Dan
So, do you have a 2 bar or 3 bar map that you attempted to use? 2 bar will allow you to read a second atmospher (bar) which is the 14.68 psi of boost, and the 3 bar is double the boost to be able to be tuned on the VE. It's read in kpa. 2 bar is 210kpa and 3 bar is 315kpa. The stock one is just 105kpa.
