Baddest small-size T4 turbo out there? Want to upgrade my TC78
#81
Looks to hold boost ok. Timing is a little lower than I'd like to see. But as stock48 said, the shift extensions are real short. So you're definitely losing some power to the converter. And the exhaust housing obviously doesn't flow enough either. Looks like its probably pretty fun to drive though lol.
#82
Reason I ask is I would like to tighten up my converter a bit, and our farm has a 55 gallon drum of john deere hygurd. I just don't want to ruin my converter or trans running it all the time if it is something that works for race cars and not recommended on the street/everyday use.
#84
9 Second Truck Club
Yes it will tighten you up a bit long as it's the high viscocity oil. They have a low vis as well so you need to find out which oil it is. I've never had a problem with the hygard in any trans except for my Duramax allison, and only thing it did with that was made converter so tight truck was laggy. Tightened that thing up like 600 rpm lol. You don't want to run it in a dd in really really cold climet
#86
I am by no means a turbo expert like some of the guys in here but I have been pretty happy with the Billet PT7675 on my 383. With the stalled auto it would spool instantly which was awesome for a street driver, I had never been in a turbo car before that felt like it. Mine was on low boost about 10psi I am not sure if I would run into back pressure issues at 15-20psi though. My only advice is stay away fromt the old school PT88s a buddy has one on his 408 and it makes crazy power but it does have a bit of lag and I can imagine on a 383 it would be pretty bad. The new 88s are fine though from what ive heard.
#89
I took another look and it APPEARS that I might fit also considerably bigger turbo. My comp cover is right near crank pulley because turbo is so short. between centers of covers there's only 4.5". If turbo would be longer, comp cover would clear the pulley much better, so even some 9" would fit provided it is further away from T4 flange... Pics will illustrate this
So what are next best turbos, bit bigger but with good flow and price?
BW's are still huge, right, almost 10" diameter cover?
#95
I don't think you need to lower the stall but if you could get it to keep from blowing thru the convertor it will be faster no mater what turbo you run .
know mater what turbo or cam you run your torque peak is going to be less than 6200 and if you are slipping past the torque peak your not going to get the best et out of the setup. if your convertor was a good 3200-3400 stall that has low slippage by 5000 you whould think you had a completely different car.
is your current convertor locking up at 6200 or is that just the rpm where your power falls off to the point that it can hold it?
#96
https://ls1tech.com/forums/automatic...ld-work-3.html
But in short, engine rpm climb to 6000 fast and converter output is 5200 at this moment. Past 6000 engine rpms climb very slowly and TC is catching up with the engine.
So it's 6000 input vs 5200 output, even with my short 3.73 gear
Does it look right? Or is it "blowing through converter"?
#97
I would have that converter taken care of correctly first before putting another turbo on. Then run it for a while and make a decision from there. My TC-76 on a 6.0 lq4 and 4l80e with a ptc converter that was tight was able to manage a 9.8@140 and I think it still had more in it. That was at 15psi. I just now switched over to a PT7675 CEA billet wheel and am supposed to get tuned tomorrow, not sure when I'll head back to the track for real results from the turbo swap. (I don't believe in dyno #'s too much as no one believes me anyways since I only made 585whp but ran 9.8@140)
#99
Guys, could you please give your advises in this thread? As to what rpms drop or converter slippage is OK and what's "blowing"...
https://ls1tech.com/forums/automatic...ld-work-5.html
