Running truck coils with your FI setup? Ditch that unsightly bracket and go billet!
Closed ex-Sponsor Account
Clean up your engine bay with our new billet coil brackets! These are designed to use the factory bolt holes on your LS Series valve covers, and use the OEM Truck coils (PN-10457730). This makes for an easy conversion for any LSx based engine to upgrade to the higher output coils or just replace the nasty stamped OEM coil bracket!
- CNC Machined Billet Aluminum
- Brushed Finish
- Made for OEM Truck Coils (PN-10457730)
- Hardware Included (Not Pictured)
- Made In The USA!
- Fits - LS1, LS2, LS3, LS6, LS7, LR4, LM7, LQ4, LQ9, L33 and more!
We can offer them without the logo if desired. Custom lettering / logos is feasible but the design/programming would be additional and for a one off project quite expensive relative to the cost of the part.
I am interested in a set of these and how you did the breather cap also. Like you hole sawed the top of the actual cap or removed the cap and then figured out a way to put a breather where the cap goes. I need to do this for some more ventilation.
you guys building LS engines???? i hope not cuase you fucked my 4g64 up bad.... who doesnt line hone after replacing the main cap bolts....
