SN95 5.3 TH400 3.27 build thread - 10.88/134.86 - NOW LQ9
#261
Shoot, I was hoping I could use the stock truck manifolds. That's a bummer. Glad yall mentioned that before I welded the v-bands on this week! lol.
Edit: so if you were to do it all over again, would you have used an aftermarket k-member? Or do you see no point in an aftermarket K for this setup in the SN95 platform?
#262
One more thing, you tested the truck pan, Fbody pan, and CTS-V pan and found that the CTS-V fit perfectly. IIRC, you said the Fbody pan fit too though but something was off about it? What was wrong with the Fbody pan? I have one laying around, but don't have a CTS-V pan sittin' around lol.
#263
Okay, awesome. Haven't made my mind up just yet about if I want to use an aftermarket K but if the stock one was easy to build around then that might be the route I take.
The front corners of the f-body pan ran right into the k. You may not have that issue with an aftermarket k. CTS-V pan was a drop-in much like the ls3 mani's
#264
If I had to to it all over again I would use regular sbc/bbc mounts along with adapter plates and then weld a piece of round tubing to each engine stand so I can run a sbc/bbc engine mount bolt right through it. That way I could get the engine even lower than where I have it and the engine would be placed back in the same spot everytime I take it in/out. Right now these F-ing 4.6 mounts have a big stud sticking out of them and the engine stands are slotted so the engine can sorta rock clockwise or CCW. I try to put it back in the same spot by looking at where the nuts were against the engine stand (where the nuts left a halo on the engine stand paint). This is bad b/c when you build a hot side in tight confines you need the engine to go back in the same spot every time.
#270
#272
If they come out to be around the same price as each other, I think it would be smart to go ahead and do the AJE k-member. That way I can use my Fbody pan I have laying around already. Also should make for an easier crossover to be made.
I appreciate your help though and answers for my redundant questions lol.
#273
The LS3 manifolds, will a 2.25" v-band be able to mate up to them or would I have to go 2.5"?
I have the truck manifolds that'll fit a 2.25" v-band but not sure if truck manifolds and LS3 manifolds are same size?
#275
What size header bolts did you use to bolt the LS3 manifolds on to your Gen III motor?
#276
Small update. Car runs a little too warm for my liking (can get to about 200* on a warm/hot day), and the cooling fan is pretty much constantly running. I was using a new factory radiator (single row), which is the same for the v6 and v8 cars. I installed a new China 2 row alum rad, which helped a bit actually but temps still climbed going up an incline or hard acceleration. Again, only when its warm out. Thanks to Andrew "Project GatTagO", I was inspired to install a C6 Corvette PWM fan and let the Holley ECM control it. This sucker moves some air at full tilt! At 90% duty cycle the fan is louder than my car! Usually doesn't have to get that high. But it actually fit pretty nice after I trimmed it a bit. Nice thing is there is no amp surge...it comes in gradually and maintains temps within 5*-6*. Right now temps are between 175-180*.
You can see the controller on the left side of the fan.
