Milled 317's pushing water? Considering 317's for my turbo build if I decide to sell my TFS 215 heads, and have heard that milling any of the stock heads may cause clamping issues at higher PSI. Would milling them .020 be ok? Aiming for 900-1000 whp on a 370. Any personal experiences with any milled stock heads and +15 PSI is welcome. |
My 799's are milled .030. Running 28psi of boost on alum block 5.3 at 950whp. Pushed water on stock 3 layer LS1 gaskets. Swapped to LS9's and no issues again. Quite a few track passes and street time. |
Wow ok, that makes me feel quite confident that I will be ok haha. From what you've seen, is .020 - .030 on stock heads typically not an issue with the majority of high power FI builds, if the build/tune is done right? |
we were running 317's @25lbs, studs, felpro MLS gaskets, were surfaced no issues.... |
what I like to see...hoping to turn my 370 with 317s up around 25-28 psi next year on q16...would be happy with 5.50s in the 1/8 butsome low 5s would be sweet. |
I'm only pushing 17psi right now on surface milled 317 heads with no issue. |
If your building the engine why not do a flat top piston? |
Originally Posted by LS1NOVA
(Post 17794992)
Originally Posted by T76s10
(Post 17797388)
I have a pair of 317's ported, w/texas speed titanium retainers and springs just freshened..540-786-8111 Rob |
| All times are GMT -5. The time now is 06:53 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
