Which bmr k member for DIY front mount?
Going to start collecting parts for a turbo build this winter. I was going to to do a front bumper exit down pipe and use the stock k member but doesn't look possible while keeping ac using a c6/truck manifold set up.
So question is use the standard turbo k member or the newer 'low mount' turbo k member? I figure if I'm going to buy a k member then ill plum in a dump off the down pipe and run a full car back for the streets.
Any thoughts?
Any thoughts?
hit up DKT. they have another option form BMR. its waht they are using on my friends build.
its like the full turbo kmember but with the DKT motor mounts that are in the low mount kit.
Is the bmr the exact same as the dkt? It looks like the bmr the bar that goes from the top mount to te rear lower control arm bolt is straight but the dkt pic it looks like it's swept like the front one or is it just the pic?
After talking with bmr today it sounds like the standard turbo k member will be better for my build. Those rear bars I was talking about would be getting in the way if my down pipe.
I tried gettig ahold of dkt to ask some questions but got no answer and no reply.
i cant find it.. but devin has a picture floating around with a coffee can stick in his... its like 6.125" lololol
LS1Tech Premium Sponsor
BMR turbo k-member (KM013)
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
