Ysi How easily would 800 rwhp be to reach with a YSI without cog drive, using 91 octane? Probably around 17lbs boost |
Very,what is your base engine to start with ? |
Originally Posted by kpadlina
(Post 17982247)
Depending on CR with your 383 I'm assuming, you can certainly do it. 8 or 10 rib at a minimum. |
Cr is 10:1 and the belt I'm running now is 8 rib so I was hoping to stay with that set up. |
the more ribs the better, but not all belt drive setups are equal. So make sure it is a damn good setup with a good sprung tensioner. |
The Ysi and F Series benefit from a more steep gear ratio allowing larger pullies to be used. I'd love to run an F-1 but I want the helical gear set more. But yes, more ribs are better for your boosting pleasure. Are you planning meth? At 10:1 w/ 91 Octane I do not see 800whp or 17psi being possible at all. Maybe 9:1. |
YSi and F-series internal gearing are miles apart. F-Series uses much taller gears and hence larger pulleys. YSi as with most Vortech is down around 3.45 |
Huh no kidding. I honestly thought is was up there with the 5.x:1 of the F series. My bad. |
I'm willing to run meth. I just wanted to stay out of the e85 group cause sometimes it's hard to get and unfortunately the gm computer can only have one tune at a time |
© 2024 MH Sub I, LLC dba Internet Brands
