What's everyone using for piston ring gap?
Old Feb 28, 2014 | 07:47 AM
quickkris2006's Avatar
Default What's everyone using for piston ring gap?
I'm building a 5.3 stock bottom end with all new bearings and a fresh hone. Mahle perfect circle rings. S475 turbo, freak show performance power glide and a 9inch with 3.50 gears.. what is everyone running for piston ring gap?
Old Feb 28, 2014 | 08:47 AM
63falcon's Avatar
.032 both rings may be a little loose but im going to hammer it hard.
Old Feb 28, 2014 | 10:03 AM
philds19's Avatar
I usually run .0055" if every inch on boost maybe upto .0065" per inch if I were gonna beat the crap out of it
Old Feb 28, 2014 | 01:13 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
My first and second rings are both at 0.024", which falls in line with philds19's range.
Old Feb 28, 2014 | 01:24 PM
novaflash2002's Avatar
Top ring .030. I leave 2nd ring alone
Old Feb 28, 2014 | 01:25 PM
Just noticed our using perfect circle. Call them and ask what they recommend
Old Feb 28, 2014 | 03:41 PM
Quickfrc's Avatar
.0055 per inch of bore on top. .0005 per inch of bore bottom.
