What compression ratio for 1000rwhp 408
Im pretty new to the FI world so plz bare with me.
Been searching for info on basically a 101 on compression ratios for boost but to no avail.
Im looking to build a boosted 1000+rwhp 408 iron block but have no idea what cr to go with. For one thing, i don't want it to be a pig off boost.
Any knowledge you can throw my way would be really nice!
Making 1000 + rwhp with 408ci will be easy with that many C.I. There are a few combination you could use but one would be 9.5 static. With the correct cam it will drive good and make the power you are looking for.
And unless it's a 5 ton truck, I doubt even a 408 could ever be considered a pig off boost at any compression.
My car weighs similar to a GTO.
Ive had 346, 383, 403 etc in mine, and none have ever been a pig low down regardless of size or compression.
If you're looking to make 1000+ on only 91 octane, I'd say keep CR around 8.5:1
Dynamic or static? 9:1 dynamic is really high IMO for pump gas and boost. Are you running race fuel?
Most of the combinations we build are 9.0:1-10.0:1 static depending on the goals of the customer.
IMO the cam used will be more important for "not being a dog" than the compression ratio used.
Im guessing SCR.
Dynamic or static? 9:1 dynamic is really high IMO for pump gas and boost. Are you running race fuel? Most of the combinations we build are 9.0:1-10.0:1 static depending on the goals of the customer. IMO the cam used will be more important for "not being a dog" than the compression ratio used.
