small turbonetics build ive decided after retiring my daily driver to do a turbo setup,im not very familiar with turbo setups or anything and im not looking for major power, rite now so im looking at options and looking at turbonetics T04E-50, 3" the truck is a 01 with a 5.3 toped off with a 78mm fast intake, would this be a good turbo to start with what I already have? |
Buy my TC78, it would be perfect for what you're doing. https://ls1tech.com/forums/parts-cla...t-housing.html I'm not just trying to sell you a turbo, that t04e is way too small for what you're doing. It would just be a restriction. |
No that's too small. If you want small, run a 66mm or a 70 |
yup, way too small! Maybe two 50's. |
What are your goals and what do you want out of the turbo? |
Playtoy mainly with the dependability of a driver, mid 450 late 400hp range |
Now would both the 50mm be to much for it? Or would the power range equal out bout the same as a larger one? |
Twin T04E's would be fine at low boost levels you will exceed your power goals. |
As long as it's manageable at low boost that will be fine |
© 2024 MH Sub I, LLC dba Internet Brands
