3.905 bore size on 4.8 iron block
I have a nice forged rotating assembly for an ls1 but I'd like to run the stronger block with a goal of about 900 to the wheels on E85 with a ttix turbo car
I've seen various opinions and boring the block .120 has me a little nervous on getting the block walls too thin to support this power level
I have a nice set of AFR 225 heads
mostly a street car but I will be beating on it at the track a few times a year and turning up the boost to get the RWHP I need to run 9s
I've got a lunati 4.0 crank rods, and wiseco pistons
if boring that much won't work, will a smaller bore size work OK with the AFR 225 LS1 heads? I like the the heads and can always use the LS6 alum block if needed. the 3.905 seems to be a "max size" for either block and only recommended for normally aspirated engines
thoughts??
thoughts??
mine is l33 block, 3.830 bore with stock 4.8 crank for 302 cu in, runs 9.7x at 139 on low boost(14psi) on e85 at 3400lbs..
has run 9.5x@ 148 on higher boost..
but i run 243 heads too..
so long story short will it run 9's.. im sure it can.. I have no idea about the rest..
I think I can bore the 4.8 block pretty safely to the stock LS1 size if I buy new pistons.
just trying to use what I have alredy which is 3.905 which looks like the biggest size to hone the ls6 out too.
I agree that keeping more meat in the block would work best for strength and and new pistons aren't that much
just have the machine shop sonic test the block first
bout 90% of the 4.8/5.3 blocks will do .120 over no problems
there is a few guys on here with iron block based ls1's boosted well over 700whp without problems
can't recall the dudes screen name atm
but he has a forged bottomend iron ls1 in a red rcsb truck pushing right at 1000whp
