Huron Speed *New* T6 Kit!
Will get you the kit much faster and also cheaper, not to mention a secret bonus savings on components to all pre-sale customers as well.The A/C kit will fit any standard T4 3" v-band turbo, so with that we have found the limit to be about 800-850 rwhp with a 3" down pipe. The new V2 A/C kit will fit a mid-frame T4, however require a 4" bumper exit down pipe for that. With this like a PT88 you could see 900-1000 range, however a mid-frame on the A/C kit will be a lot of packaging and if over 800 rwhp is your goal, along with A/C not being a complete deciding factor, I would opt for the T6 kit for sure due to design, ease of install, wow factor when you open the hood, etc. If A/C is a 100% deal breaker, then obviously go for the A/C kit
Overall the cost of that kit will be a touch cheaper initially but will require a turbo k-member to clear piping around the A/C compressor so it may make it touch more after you factor that. All in all when you do the radiator for the T6 kit, I would bet the T6 kit and the A/C kit will end up running very close in price to one another
All really depends on exactly what you want. If you need A/C, obvious that will decide the kit. If it isn't all that important to you and you want to make bigger power with a flashier, in your face kit when you open the hood then the T6 is your choice for sure!
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Also is there a bung installed anywhere for a thread-in style intake air temp sensor?
We can add in a threaded bung to the cold side pipe for you no problem as well, just let us know your location preference
Jon
If you are interested in this kit, get your deposit in TODAY so you don't miss out on longer wait times and higher pricing!
Place your deposit here to reserve a kit:
http://shop.huronspeedproducts.com/H...Kitdeposit.htm
Radiator, Circle Track, Aluminum, Natural, Crossflow, 2-Row, 27.5 in. Wide, 15.5 in. Height, 3.0 in. Thick
(Mfr. #: 1-58241-XLS)
