Starting my 04 CTS V twin turbo build
I finally get to start on my twin turbo build for the v. I have a lot of questions and would like any kind of input I can get. This will be a slow build, but I will keep it updated. This will be a street car, and maybe see the track a few times.
The build:
lq4 370
317 untouched heads
Trunion upgrade
ls9 gaskets
tu1.5 cam
twin turbonetics t3/t4 .63 turbos spec'd by huron speed
precision 39mm wastegates
91 octane with meth
fic 2000 injectors
Goal, 1000whp
The only things I have now is the lq9 and turbos. So if you would suggest anything different, let me know. Few questions,
What should I run for compression? I was leaning towards 10:1
What intercooler would you recommend? Treadstone?
Being this is an ls6, would that have the same reluctor wheel as the 02 lq4?
The victim
The build:
lq4 370
317 untouched heads
Trunion upgrade
ls9 gaskets
tu1.5 cam
91 octane with meth
fic 2000 injectors
Goal, 1000whp
The victim
I'd be more worried if it was a stock rear diff/suspension assembly 1st gen...cause that...would be a waste of a power plant. It's like being billybadass boxer but you have a glass jaw.
No bueno. In for the build though, car looks good.
edit:sig says diff mods.
