Vortech G-Trim SQ version LOCKED UP!
Just speculation on my part.
Steve
"Generally speaking, though, Helical Gears are capable of carrying heavier loads than Spur Gears. They are also capable of operating between shafts that run at an angle to each other. One potential downfall with Helical Gears is that they do produce thrust loads along the shaft. The higher the Helix angle, the greater the thrust produced. This must be taken into consideration when choosing supporting bearings for the shaft. "
