LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Forced Induction (https://ls1tech.com/forums/forced-induction-9/)
-   -   PIc's For You Guys (https://ls1tech.com/forums/forced-induction/174117-pics-you-guys.html)
NA$TY-TA May 21, 2004 03:43 PM
PIc's For You Guys
Most of it will be going on tonight....... Like Jeremy said ATI messedd up and sent us botht the rong blower pulleys...... but Wendy was all over it and made them ship out another one today.... 1day air forf a Sat delivery at no cost to me........ AWSOME CUSTOMER SERVICE. :nod: :cool: OK OK here ya go :devil:
http://www.itlxlr8.homestead.com/fil...sioned8rib.jpg
http://www.itlxlr8.homestead.com/fil...ioned8rib2.jpg
http://www.itlxlr8.homestead.com/fil...ioned8rib3.jpg
More later im off to work on it.... and i even got a cool free shirt... :cool:
Kyle
BIGBOS May 21, 2004 03:45 PM
Looking good :)
They SHOULD have my bracket today, if not, they will get it monday, hopefully I can get my hands on it early next week, get the crank pulley pinned to the stock balancer, and then off to the dyno once again :)
Kyle what size blower pulley did you go with?
frcefed98 May 21, 2004 03:52 PM
GIMMIE GIMMIE I NEED:(
Looks awesome, I hope I get a t shirt too....and STICKERS:D:jest:
I going to print these out and tape them on the car and make cool blower sounds...later:)
BIGBOS May 21, 2004 03:54 PM
I want a free T too, XL wendy if you read this ;)
frcefed98 May 21, 2004 03:55 PM
Whats in the plastic bag:D oh yeah XL for me too, will that fit a 220lb'er?
J:D
BIGBOS May 21, 2004 03:58 PM
XL's fit me, I'm about 220 :)
kp May 21, 2004 04:04 PM
I thought you guys drilled the extra hole in your brackets. There is one unused bracket to blower bolt (3/8) that for some odd reason ATI doesnt use in the bracket. I thought it might make the bracket prone to crack there but mine has been holding up fine. Takes like one minute to drill and countersink it (the blower makes a good impression of it on the back side so its easy to locate if the bracket is used). It makes the whole thing a lot more solid.. I dont have a pic of mine off the car but i'll mark your pic Kyle. Without the extra bolt you can pry the blower away from the bracket - using it the head unit doesnt budge.
frcefed98 May 21, 2004 04:04 PM
I used to get a ton of free t-shirts when I worked in the grocery business, hard liquor,beer,cigs and the occasional racing promotion/beer shirts and I never paid attention to the size of them, all I know is that is all I wear now lol. I have BIG MUSCLES YAH! lol:D
Blackbird May 21, 2004 04:49 PM
I didn't get a T-shirt and I waited 6 months and still waiting on 1 part !!!!
Man I got hosed. :( :( :( :(
Well I am glad you guys are getting taken care of at least.....
Looking forward to seeing how you like it tommorrow.
GrezMunky May 21, 2004 04:59 PM
Heath, What are all the washers and 2 different size bolts for??? I know soem of the washers are for the standoffs...... can you explain it since you have your kit?? This is Kyle posting under my friends account at his house..... im about to start...... letting car cool down......... Iron holds a little more heat in...... I have a fan on it.
kyle
Blackbird May 21, 2004 05:16 PM
your block may be different but on the ones I have done, you use 2 of the thicker washers per standoff to space out the blower to get it aligned with the crankpulley.
show me what bolts your talking about. the only one I can think of is the little guy to bolt the support brace to the blower.
Also please note you must remove the tensioner from the assembly in order to bolt the bracket back up. Seems obvious to some but I had to ask because I thought maybe there was a reason they shipped it bolted to the bracket.
Again may seem obvious but put the washers between the standoffs and the bracket. Not on the other side. Look at my pics if you need to.
http://buddy.abbate.org/blower.htm
GrezMunky May 21, 2004 06:20 PM
Its Kyle...... Did you put washers on the tensioner like in ths pic???
http://buddy.abbate.org/images/P1010088.JPG
can you PM me your cell or home phone number..... to Na$ty-ta ill log on
Kyle
frcefed98 May 21, 2004 06:46 PM
Do you mean the top spring tensioner or the middle one? I want to be sure I have all this right before I get mine in.
Man I got hosed.
I told wendy that you were my referral since you pointed me in their direction:D Maybe that will help?
Kyle keep posting what you are doing.
Thanks,
Jeremy
SDCE May 21, 2004 07:16 PM
Kyle
Kyle,
Scott just looked at your pics and said where you have the wahsers is fine...
Usually it takes .250" (2 of the thick washers) to line it up but you HAVE to check it with a straight edge like Heath recommended in a previous post somewhere...the two different 5/16" 18 bolts are for the support brace...you have to pick one...use whichever one fits the best without stretching the blower over and without bottoming out...put it on the oilpan first...stick the shim in to fit snug(pick any combo of the 3 washers) then try the 2 bolts to see which fits the best...
frcefed98 May 21, 2004 07:25 PM
RIGHT ON! MY STUFF SHIPPED TODAY:gruffy: I WILL HAVE IT TOMORROW. WENDY@SDCE IS AWESOME.:hail: She also had ATI NEXT DAY MY S/C PULLEY TOO. SDCE ROCKS.
Thanks Wendy and Scott:D
Jeremy
SDCE May 21, 2004 07:52 PM
Heath...good things come to those who wait! :)
you have two referrals btw....I (think) I got your belt coming too....we've had such a mess with pulleys and belts... :bang: ....I'll check in with you on Monday....
Blackbird May 21, 2004 07:58 PM
I guess I am gonna get lots of good things :) :)
You know I support you guys. Just feels good to whine once in a while ;)
GrezMunky May 21, 2004 08:35 PM
Thanks,
Jeremy
I got it now........ ill take some pics..... and look close on the directions from SD.... the arrow is really faint and hard to see...... Crank bolt is in... going to finish on my car fo rthe night and put my buddys cam in and change valve springs...... more on mine after my blower pulley shows up tomorrow.
Kyle
1dirtyZ May 22, 2004 12:09 PM
any updates?
frcefed98 May 22, 2004 12:33 PM
I got mine in at 8:40 this morning and the s/c pulley at 9:30:hail: Its 11:30 now, I wasn't use to the gap between the crank pulley and the balancer being so wide, but the SDCE crank pulley is quite a bit deeper than the other pulleys I have......I thought something wasn't fitting right but after looking over blackbirds pics again:whew:
Now its time to put it all up....back to work.
J:D
© 2026 MH Sub I, LLC dba Internet Brands
