Some video's from the last race
Old Sep 9, 2014 | 07:48 AM
Slowhawk's Avatar
LS1Tech Sponsor
Default Some video's from the last race
Made it to the finals in our local X275,
My car is an overweight street car but does ok up here for some fun.
Best of the day was a 5.26 at 139mph with a 1.29 60'
Been fighting minor issue's all year with boost and getting off the line.
Car- 99TA
427 LS2 block with a GT45/55/88mm From Jose
TEA/TFS heads
242 cam
bolt down Yella terra's revving to 7800rpm
TH400 from RPM with PTC converter
Midwest 9" with 3.50 gears
Alky control meth kit
Old Sep 9, 2014 | 08:02 AM
a98ws6's Avatar
Nice! What did the other guy run? I seen you pointed at the wall for a second there.
Old Sep 9, 2014 | 08:32 AM
Slowhawk's Avatar
LS1Tech Sponsor
Depends on which race. The yellow stang jumped the beams before they activated and ran a 5.3 to my 5.2.
The final, the guy ran 4.95. I turned it up hard but it wouldn't hold the launch.
sucks being 350lbs overweight for the class.
Old Sep 9, 2014 | 08:44 AM
63falcon's Avatar
Factory ls2 block?
Old Sep 9, 2014 | 09:08 AM
9sectruck's Avatar
race weight? what kinda split does the car have for weight?
Old Sep 9, 2014 | 10:10 AM
Slowhawk's Avatar
LS1Tech Sponsor
Factory LS2 re sleeved for 1.25" bore.
Here is the build thread https://ls1tech.com/forums/forced-in...8mm-setup.html
Car has about 70-80 passes on it. Weight is 3350-3375lbs most of the time.
Corner balance- I forget what we set it at. Car hooks 1.21-1.29 60's consistently with the wheels lifting 4" max.
Max boost is 22lbs.
