Largest Procharger available with truck brackets?
Old Sep 30, 2014 | 10:55 PM
BanditDave's Avatar
Default Largest Procharger available with truck brackets?
This may be directed towards Bob @ Brutespeed but I wanted to see if anyone was running bigger than a D-series charger on their truck accessory drive setup? I can't fit a vette drive due to pulley interference but the truck drive is good to go.
Is the F1-A available in the proper rotation and bolt pattern for the 5.3 truck drive with an LS9 cam???
Thanks in advance
Dave
Old Sep 30, 2014 | 11:52 PM
Blown06's Avatar
8 Second Truck Club
Anything up to an F2 will physically bolt up....and can be had in the proper rotation. Volute discarge can be adjust to about any location.
Old Oct 1, 2014 | 05:20 AM
BanditDave's Avatar
Thanks, I figured that was the case. My concern lies with the physical distance of the blower from the centerline if the motor, belt length and resulting issues that could arise. Wondering if it is possible to fit up a vette kit to keep it more balanced?
Old Oct 2, 2014 | 01:12 AM
Blown06's Avatar
8 Second Truck Club
If I'm not mistaken, the centerline of the input shaft is the same in relation to the bracket bolt holes.
Just tell us what your trying to do.
Old Oct 4, 2014 | 07:28 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thanks in advance
Dave
The problem with using the ProCharger truck bracket assembly is you end up with a six rib belt running the ProCharger. Belt slippage is practically inevitable with a blower larger than a D-1SC. I have been selling the ProCharger Transplant kit to customers with trucks. The Transplant kits can be had in 8 and 12 rib, and in a cog belt. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Oct 5, 2014 | 12:40 AM
Blown06's Avatar
8 Second Truck Club
I'm currently running the transplant cog kit and it has held up very nice. Made a few mods to integrate it into the motor plate and run a strut brace to the radiator core support. I've not chewed one single belt.
Old Oct 5, 2014 | 01:04 AM
ScreamingL's Avatar
Changing Names
on subject of largest procharger on truck brackets... how much gain vs worth is the d1sc over the p1sc? using a truck crank pulley with a 3.2 upper pulley i see 12-13 psi at 6000 rpms but believe blower is maxed as freeing up the exhaust gained nothing
made 540/554 thru a 6l80
Old Oct 5, 2014 | 08:44 AM
LS1Tech Sponsor
The D-1SC is usually good for 3 to 4 more psi over a P-1SC. At any given amount of boost you won't be using as small of a pulley with a D-1SC, which helps with belt wrap. I would say your 12-13 psi with a P-1SC is topped out, that's good boost out of a P-1SC. Bob
__________________
Old Oct 5, 2014 | 08:45 AM
LS1Tech Sponsor
Bob
__________________
Old Oct 5, 2014 | 09:34 AM
ScreamingL's Avatar
Changing Names
dunno how but right now i havent seen or noticed any belt slip. theres no dust or squealing with this combo. I know i had found a tight belt and using the 99-02 bracket on a 2010 truck. I have teh 145 amp alt which keeps it from tossing belts in the last 10k miles.
what is the price of a d1sc head unit?
can the p1sc head unit become a d1sc?
at same boost pressure how much more volume will the d1sc flow vs the p1sc?
will the d1sc come in any sooner or is the p1sc the best for instant power? truck is used for towing and does well doing so just was wondering about more power with less boost
Old Oct 5, 2014 | 11:59 AM
LS1Tech Sponsor
That's good news!
Give me a call for head unit pricing.
Yes, the P-1SC can be upgrade into a D-1SC.
http://shop.brutespeed.com/ATI-PC015...PC015A-010.htm
It tends to be cheaper to sell your head unit and buy a new D-1SC.
Not sure how much more volume the D-1SC will flow over a P-1SC at the same boost pressure. With the D-1SC not having to spin as fast to make the same amount of boost the P-1SC produces, the inlet air temps tend to be cooler, which helps in making more power.
In theory the P-1SC should come in sooner, but I have never been able to tell a difference.
If you don't have methanol injection on your truck, you might try going that route first, methanol tends to drop the inlet air temps 35 to 40 degrees when it kicks in under boost, which makes for a good hp increase.
Thanks. Bob
__________________
